soccermud
Member since July 2008
Post by soccermud on May 10, 2009 18:16:32 GMT -5
Hey all, quick question. When I'm tumbling in the coarse grit stage and I go to recharge the grit, should I be taking out certain stones and replacing them with more? If so, which stones should I be taking out? Rounded ones, ones with cracks, ones with pits?? What should I do with the stones with cracks and pits? Thanks for helping.
Chris
Rogue Trader
"Don't cry because you are leaving, smile because you were there."
Member since December 2008
Post by Rogue Trader on May 10, 2009 18:27:09 GMT -5
Chris, When checking/recharging, I just check for progress of the rocks. If there are any with natural defects showing, then I'll take them out (basically) bash them with a hammer to reshape, then return to barrel to continue with mother load. Otherwise it is personal choice - remove stones ready for next stage or remove (and replace) defects. Either way your barrel is going to need refilling with newer rocks. Not much help I know, but you did ask
ejs
Post by ejs on May 10, 2009 22:04:04 GMT -5
Hi, Chris. When I recharge (which I do every 5-6 days of 60/90 coarse in my Lortone QT66s), I rinse the rocks and give them a look. If any are well rounded and in a shape that pleases me, I set them aside to go on to the next stage. I put all the others back, and then add fresh rough to bring the barrel up to 2/3-3/4 full: Water + grit + start again. If a rock has any kind of groove or pit, I'll keep it for another round. It will typically take at least 3 rounds (for soft stone) and possibly up to 8 rounds (for harder stuff like some agates) before I get any that are ready to move on. And then another bunch of rounds until I have enough ready for the medium stage. So, for a typical tumble, I'll run 10-15 rounds of coarse with a recharge between each. But I like my stones to be quite well rounded, so it takes me a long time: Many other folks prefer a more "natural" shape and so will run fewer rounds. Find what makes you happy. Good luck and be patient!
