Post by deb193redux on May 29, 2009 22:18:55 GMT -5
This is one of the nicer and larger Crazy Lace slabs I have, but I think I will end up cutting it. I played with it in photoshop this evening. (click for full size) Can't pick a favorite. What's yours?
lapidopterix
Member since March 2008
Post by lapidopterix on May 29, 2009 23:48:53 GMT -5
That's a lot of nice cabs for just one slab.
Could you make a tutorial for your photoshop process? I'd like to try it out but I have no clue how to do it.
Post by deb193redux on May 30, 2009 11:45:24 GMT -5
Sure. I will put an initial tip sheet together this weekend. You can rotate the picture and then select an oval and copy it to a new picture with a dark background.
There are additional steps to allow selection of other shapes -(even to make templates)-, to produce the slightly rounded edges, to correct the color after a slab is scanned. There is additional knowledge about rotating the picture OR the template. These will all take a bit more effort to illustrate.
But, lets start with the oval.
adrian65
Member since February 2007
Post by adrian65 on May 30, 2009 12:16:25 GMT -5
Beautiful slab! Hard to pick favorites, indeed. Mine are first row-first from right (egg) and 2nd row-2nd from left (trapese).
Looking at you positionning of the cabs on the slab, you must have a very good trim saw: so small clearance between them, I wouldn't dare to try cutting them.
Adrian
lapidopterix
Post by lapidopterix on May 30, 2009 16:40:02 GMT -5
Sure. I will put an initial tip sheet together this weekend. You can rotate the picture and then select an oval and copy it to a new picture with a dark background. There are additional steps to allow selection of other shapes -(even to make templates)-, to produce the slightly rounded edges, to correct the color after a slab is scanned. There is additional knowledge about rotating the picture OR the template. These will all take a bit more effort to illustrate. But, lets start with the oval. That sounds great. Now I'll have to find my photoshop disk and get it installed on this computer.
Post by deb193redux on May 31, 2009 13:13:50 GMT -5
Do you have PhotoShop or PhotoSHop Elements - both can do mostly the same thing for virtual cabbing, but the menus are different
Post by frane on Jun 1, 2009 10:17:50 GMT -5
That is a very pretty slab but I think it will be hard to get all of those cabs out of it. Hard to get the saw through those little spaces unless you have a diamond bandsaw. That may be tricky too. Good luck! Fran
Post by stonesthatrock on Jun 1, 2009 10:58:15 GMT -5
daniel tried to teach me once, but i forgot heheheheh i hope he makes the tutorial. nice piece of lace too, btw.
Post by deb193redux on Jun 1, 2009 12:16:06 GMT -5
That is a very pretty slab but I think it will be hard to get all of those cabs out of it. Hard to get the saw through those little spaces unless you have a diamond bandsaw. That may be tricky too. Good luck! Fran Some adjustments might be needed. The ovals especially might get a bit smaller. They are the afterthought anyway. Also some of the bolo may get reduced by 1/16 inch in each direction. I did reduce one just a bit in order to get the picture cut. I would start with the ones I want most and which can be gotten to the easiest. I also do plan to get another band saw next year. I traded away my Inland band saw 2 years back, but I have been looking closely at the C-40.
lapidopterix
Post by lapidopterix on Jun 2, 2009 1:36:36 GMT -5
Do you have PhotoShop or PhotoSHop Elements - both can do mostly the same thing for virtual cabbing, but the menus are different Photoshop
Post by NatureNut on Jun 2, 2009 7:35:46 GMT -5
Awesome slab, Deb. My fav is the second row, third one in (to the right of Adrian's fav). Virtual cabbing looks fun! Jo
Post by Tonyterner on Jun 3, 2009 12:50:27 GMT -5
I never tried that but I don't have Photoshop. Always enjoy seeing you do this Daniel.
