Post by rocklicker on Jun 17, 2009 16:46:33 GMT -5
I have a batch of Jamie's chrysocolla going right now. It's at prepolish (tripoli), so I am rounding the bend. Can anyone recommend a good final polish for chrysocolla. I have never tumbled the stuff before so I have no idea what the best way to polish it is. I am used to polishing with cerium. Any thoughts? Steve
Post by stonesthatrock on Jun 17, 2009 17:46:58 GMT -5
ralph uses zam but we have never tumbled it
may ann
Post by Jack ( Yorkshire) on Jun 18, 2009 2:14:16 GMT -5
Hi Steve,
I was going to reply I use Zam !!!!!and May Ann has beat me to it !!
I have some of Jamies Crystacolla and it undercuts a lot in the Vibe, But if you have a different batch it might not have the soft spots in it ,
Check it with a Loupe when you wash it and see if it is a smooth finish or is undercutting
I cut it shape it and then flat lap it and finally polish it with Zam and it really comes up great
Jack Yorkshire uk
Post by johnjsgems on Jun 18, 2009 8:33:53 GMT -5
I was told chrome oxide works like Zam when tumbling but never tried it. Really fine aluminum oxides should work also (.2-.3 micron). Vibradry from Diamond Pacific polishes everything in a vibe.
Post by Deleted on Jun 19, 2009 3:15:06 GMT -5
JEFFD
Member since December 2004
Post by JEFFD on Jun 19, 2009 17:23:19 GMT -5
I used Aluminum Oxide from the Rockshed. Came out good but not perfect. Soft spots had a satin finish with the harder places polishing very well. It was a Lot-o batch.
Post by Sabre52 on Jun 19, 2009 21:42:36 GMT -5
Yeah, I used Rockshed AO with similar results. Shiny on the hard spots and satin finish on the softer. Still was a really colorful material though.....Mel
Post by johnjsgems on Jun 20, 2009 13:50:22 GMT -5
Most of the tumbling grade AO polishes are 3-4 micron. That usually works great on harder stones.
