pporky
Member since May 2007
Post by pporky on Jun 19, 2009 3:12:29 GMT -5
Gday after readind somebodies post about slabbing endcuts glued to a piece of wood I gave it a go and got a couple of niice slabs, thanks for then tip ribbonstone and an agate. p.s my stones still stuck to the wood been in a bucket of water for a week now it is cold, do I need warm water? pporky
10thumbs
I want to be reincarnated as a dog.
Post by 10thumbs on Jun 23, 2009 13:59:40 GMT -5
I need to utilize this tip too so I'm anxiously awaiting an answer. I've heard that Gorilla Glue will come loose in hot water. Maybe you could fill a shallow baking pan with water, put it on the grill and put your slab in there slab side down. This is just off the top of my head. I have never tried it.
If that doesn't work an acetone soak might however it might be tricky if you can't soak it in something you can put a cap on. In my experience acetone evaporates really quickly. Maybe on old paint can would work if the slab is small enough. I don't have a great sense of scale from this picture.
Post by Tonyterner on Jun 23, 2009 14:59:49 GMT -5
Good tip, I never heard that one before. What kind of glue did you use?
Post by catmandewe on Jun 23, 2009 18:32:25 GMT -5
Use good old elmers glue, I have used wood glue and it will work, too but it takes longer to get the last slab off the board. Elmers white glue will come apart after a few days, float the board in a bucket of water with the slab down in the water, eventually it will fall off the board and sink to the bottom of the bucket.
Glad someone got some use out of that tip!
Tony
