buck570
Member since February 2009
Post by buck570 on Jun 30, 2009 21:54:52 GMT -5
AS i don't have the means to grove a cab as I've seen on this site before , i was thinking of how i can use my work force. Using plexi to raise the table so only a small portion of the blade is exposed,and a plexi fence to rotate the cab against. Any thoughts on this ?
adrian65
Member since February 2007
Post by adrian65 on Jun 30, 2009 22:43:55 GMT -5
The idea sounds great, only take care at the thickness of the blade. It might be pretty thin.
Adrian
PS. The cut through that plexi raising table might be pretty tight, close to the blade that protrudes through it. This way you will have a good control of the depth.
Post by johnjsgems on Jun 30, 2009 23:38:27 GMT -5
I think a tile blade would be too thick, giving you too wide a groove. A low cost way would be a "V Wheel" in a drill or rotary tool. Those are about $7. You would need a steady hand.
Post by Hard Rock Cafe on Jul 1, 2009 12:47:25 GMT -5
I also think the tile blade would be too thick. Get some 20 gauge wire and compare it to the kerf of the blade.
I'm learning to groove using a Dremel with a diamond wheel mounted in the Dremel drill press ("workstation"). I need to create jig to control the depth of the cut; shouldn't be hard.
