bendsum
Member since October 2008
Post by bendsum on Jul 11, 2009 1:17:35 GMT -5
My dad told me about this it was at a weekly auction no bids even at $5 it comes with motor is mounted to a large table so my question is with a few mods and add ones could it be converted to a grinder ![](http://img.photobucket.com/albums/v33/bendsum/grinder.jpg)
drjo
Honduran Opal & DIY Nut
Post by drjo on Jul 11, 2009 7:44:15 GMT -5
Sure, a little splash proofing, a 80g diamond wheel, and an expando wheel with an assortment of belts and your well on your way to a bull wheel www.kingsleynorth.com/skshop/search_results2.php?catID=917 or better. Space your wheels as far away from the bushings (bearings) as you safely can to lessen water problems. Keep us posted on your progress and have fun. Dr Joe .
bendsum
Post by bendsum on Jul 15, 2009 1:24:08 GMT -5
well i won the arbor at the auction it went for $10 with lamp and table also a roll of 1/4" solid copper wire problem is the shaft is to short and it 1/2" so i need a longer one and this is a stupid question how do the grinding wheels go on the shaft ? are they held with a nut or set screw ?
Post by johnjsgems on Jul 15, 2009 8:14:27 GMT -5
If the shafts are threaded they usually have nuts (left side left hand thread). If not they can be set screwed or there are "shaft adapters" that go on the shaft to provide nuts/washers. Look at Covington's online catalog and you can see these. They also make a similar "open arbor". 1/2" shaft is fine. You can use telescopic bushings to adapt 1" wheel arbors. The shaft sticks out past current wheels so plenty long enough to install a wheel and drum or two wheels.
Post by johnjsgems on Jul 15, 2009 8:16:07 GMT -5
Another thing, make sure motor is 1725 rpm not 3450.
drjo
Post by drjo on Jul 15, 2009 18:17:13 GMT -5
