bendsum
Member since October 2008
Post by bendsum on Jul 19, 2009 15:46:31 GMT -5
Ok dad brought home a sewer cleanin machine it has a 1/3 horse 1725 rpm motor and i think 4 pullies to make the shaft turn real slow the shaft is 1" so any ideas ??
Post by texaswoodie on Jul 19, 2009 21:16:49 GMT -5
Bring it to my house and clean out these durn sewer lines of mine. ;D
Maybe a giant tumbler?
Curt
Post by johnjsgems on Jul 20, 2009 0:00:41 GMT -5
If the motor is "continuous duty" rated you could build a tumbler. My Highland Park 40 lb. had a 1/3 hp, 1725 motor. You could also use a 1/3 hp to run most cab machines, arbors, trim saws to 10" or so.
bendsum
Post by bendsum on Jul 20, 2009 1:17:05 GMT -5
what speed is needed for a flat lap it might be a little over kill i will post a pic or three soon
Post by johnjsgems on Jul 20, 2009 9:27:39 GMT -5
It would be fine for driving the old style hold by hand flat lap used with grit. You would pulley the speed down to 500 or so to not throw your grit. The diamond disc laps are usually variable speed to either 2200 or 3450 rpm.
drjo
Honduran Opal & DIY Nut
Post by drjo on Jul 20, 2009 11:13:09 GMT -5
Robotic rock separator (may need a few other parts too ![;)](//storage.proboards.com/forum/images/smiley/wink.png) ) Make an arbor and mount 4 - 1.5" diamond wheels side-by-side for a 6" wide grinding wheel and be the envy of the rock polishing world. Drive system for the rock feed on your home-built 36" slab saw. Use to drive the auger to add grit to your DIY 48" multi-layer flat lap. Use it to drive a fan to keep you cool while your working on these other projects. Set it on a shelf in plain view so you can tell allyour RTH buddies what your ' going' to do with it. And if your Dad is bringing this good stuff home, maybe you should start hinting at other pieces (like pillow block bearings (think air handlers for large A/C systems), 18" - 24" plate steel discs, old belt grinders (for their wheels), arc welder, lathe (for making a rock lathe), etc. P.S. I hope you got him a really nice Father's Day card. ![;)](//storage.proboards.com/forum/images/smiley/wink.png) Dr Joe .
bendsum
Post by bendsum on Jul 20, 2009 20:28:54 GMT -5
it may just get shelved for now got to many projects going between workin flintknapping building a 14" swing arm saw i dont have time for much else
Post by johnjsgems on Jul 20, 2009 23:16:02 GMT -5
If I remember right, my funky old 14" drop saw has a 1/3 hp motor. It is a very versatile size.
