karock
Member since November 2007
Post by karock on Jul 24, 2009 11:22:46 GMT -5
I thought i would ask the pro's I have a MK 101 Tile saw. I mostly cut by holding the stones. Yesterday the blade started to do some weird wobbling. Is this the result of a bearing going bad or the blade (10" HUSKY from HD) getting worn out? Karock
Post by texaswoodie on Jul 24, 2009 11:54:48 GMT -5
It could be either one. Take the blade off and lay it down. Put a ruler or other straight edge on it to see if it's perfectly flat.
Work the arbor back and forth to see if you have any slack.
Curt
Post by johnjsgems on Jul 24, 2009 14:25:19 GMT -5
Those are really tough saws but all things wear out. Most likely a dished blade from hand feeding. What Curt said sounds right.
