rockdewd
Member since October 2007
Post by rockdewd on Aug 26, 2009 16:38:33 GMT -5
I got my Star Diamond vibe lap used like I got all of my equipment. It didn't have a polish pad and I've been experimenting with trying to find the right polish pad.
I've been using a cheap welcome mat from WalMart that I cut a circle out of but it takes a while and tends to leave patterns the way the rug is woven.
I'm using micro alumina as polish.
What works for you?
Post by johnjsgems on Aug 26, 2009 21:24:34 GMT -5
Rick, most come with a felt pad. I'm guessing nylon carpet would work also. I used cerium on my Lortone when I had it. It worked most of the time. I've heard Tin Oxide is the best polish for vibe laps (this from Val Carver, manufacturer of Meyer's Rapid Polish)
scottyh
Member since November 2007
Post by scottyh on Aug 27, 2009 1:54:08 GMT -5
I just use carpet (wool or nylon-anything I can get) and a tin oxide slurry and have had no problems,
Cheers Scott
Post by tortuga on May 13, 2010 21:18:00 GMT -5
carpet store remnants. look for something nylon synthetic, i get doormat sized pieces for $0.50-$1 which i can cut 2 pads out for my 10" lapper. at those prices, you can afford to be liberal with changing them out.
