gizmo2
Member since September 2009
Post by gizmo2 on Sept 7, 2009 8:46:33 GMT -5
Can I use my dremel for polishing or just for cutting and sanding?What type of bits do I need?Thanks Mike
Post by johnjsgems on Sept 7, 2009 9:16:02 GMT -5
With hard felt bobs and wheels you can use either diamond polish or polish compounds. Bobs and wheels are available either mounted on stems to fit the Dremel or unmounted and used with a mandrel.
Post by Noosh9057 on Sept 7, 2009 10:57:13 GMT -5
Well I have a Dremel and I did not know you could polish with is. What do the felt bobs and wheels look like. Were do I get them.
Thanks Roger
Post by Hard Rock Cafe on Sept 7, 2009 12:36:27 GMT -5
You can get them at Home Depot, Target, Wal-Mart, or other places that sell Dremel accessories. They're very common and look like white felt cylinders or disks. Home Depot also carries polishing compounds in stick form from Ryobi.
Post by johnjsgems on Sept 7, 2009 14:49:54 GMT -5
If they have a choice hard felt works better on rock. Softer buffs are more fore metal polishing. I'm guessing their stick polishes are also metal polish. If they have green rouge it can be used on turquoise and other softer stones. The softer buffs also.
