rallyrocks
Member since November 2005
Post by rallyrocks on Sept 14, 2009 17:06:59 GMT -5
*L* Daniel, I hate to quibble here but the Texas or Western bow tie is the old four in hands/ string tie. Not really string tie like a bola which is, I think, a rather modern Arizona development (1940's) Texas bow tie is kind like a regular formal bow tie out of cloth but with long droopy tails hanging down. They sometimes call them string ties which leads to confusion with bolas but they're not actually string but just skinny cut fabric. This style tie is much older. I wouldn't know except I used to have one of them fancy Texas style western get ups.....Mel And not to belabor the point, but I've always thought that "four in hand" was a type of knot for regular neckties, an alternative to the Windsor knot; en.wikipedia.org/wiki/Four-in-handpuritan.kissblogs.com/blog/_archives/2006/6/8/2012730.htmlAnd low and behold- Texas has made the Bola tie their "official state tie". Also interesting that while Patents and trademarks were issued in the 40's and 50's there are bolo ties that are said to date back to the 19th century. I think I know the bow tie style you know as the string tie- like Col Sanders used to wear, right? But pretty much all modern references to "string tie" seem to point to the Bolo or Bola style. How on earth as thread about jasper spheres got moved onto ties...(?!)
1934new
Member since August 2009
Post by 1934new on Sept 14, 2009 17:15:24 GMT -5
Im sorry I asked
Post by deb193redux on Sept 15, 2009 7:24:50 GMT -5
interesting. ... not sure where I 1st heard the term ... Arizona bow tie does not sound as poetic
Post by Sabre52 on Sept 15, 2009 8:52:38 GMT -5
Rally: You're right, that is the name of a tie knot too but the Four in hands is also a tie type. I'll have to trust you on the official state tie thing as I've never seen that anywhere but I must admit, they are popular here. That must sure piss the Arizona folks off seeing as how they claim they invented it *L*.....Mel
Post by johnjsgems on Sept 15, 2009 9:01:33 GMT -5
I'd like to see pictures of the core drill. Is it a Manta? It takes a serious drill to run 7" bits and bits need to be custom "soft matrix" bond to cut jasper/agates. Also, how long does it take to core through something that large? Sorry, I'm an equipment junkee.
Post by Sabre52 on Sept 15, 2009 14:22:48 GMT -5
Me too, I'd love to see step by step pics of the drilling operation and set up. Iive a friend who cuts spheres but he shapes his with only a big set of saws. Never seen drill that big before.....Mel
Post by Jack, lapidaryrough on Sept 16, 2009 7:47:57 GMT -5
Emerson.com Contact Us Careers RIDGID Tools and Accessories Products Service, Warranty, Literature Support RIDGID Forum Forum Local and Online Distributor Listings Where to Buy Merchandise, Calendar, News, Events About Us
* Core Drills * Core Drill Bits
Privacy Policy
Find RIDGID on:
Share this page: Bookmark and Share Home > Products > Pipe and Tubing Tools > Cutting & Drilling > Core Drilling > Core Drills Product Demos Current Promos New Products Email this Link RB-214 and RB-215 Core Drills Models RB-214/215 Owner's Manual Parts List Where to Buy Service Center Print This Page Ridge Tool offers two models of large capacity Core Drills. The RB-214 is provided with a combination anchor/vacuum base which permits the user a choice of anchoring systems by incorporating the two types of systems in one base. The RB-215 is ideal in that its base is designed solely for anchoring by masonry bolts.
Features Control panel with separate switches for drill and vacuum, and amp meter to measure load. Heavy-duty plate type slip clutch protects gearing, motor, and bit – no shear pins. Two-speed operation matches bit size – 1200 rpm to 4" (100 mm) – 450 rpm to 4" (100 mm) and larger. Ceiling jack screw. Extra-long feed handle for operator ease. Large diameter wheels for easy movement.
Specifications Motor: 2-speed, 20 amp, 115V, 450/1200 rpm (230V upon request). Drilling: 1/2" through 14" dia. (spacer required over 10”). Base: Anchor/Vacuum 13" x 17". Mast: 2 1/2" square x 42" high. Slide Carriage: 5" x 5" x 10" Single-Piece Aluminum 18" Feed Handle. Control Panel: Heavy-Duty Box, Amp. Meter 2 Switches, 2 Outlets. Vacuum System: Gast Diaphragm Pump with Gauge & Fittings. Output Spindle Shaft: Thread Size 1 1/4" – 7 UNC. Models RB-214/215
Ordering Information Cat. No. Model No. Description Weight lb. kg 98090 RB-214 Core Drill with Vacuum Motor and Seal 115V 146 1/2 66.5 16372 RB-214 Core Drill with Vacuum Motor and Seal 230V export 146 1/2 66.5
Core Rig Accessories Cat. No. Description Weight lb. kg 98165 Small Anchor Base (7" x 12") 24 1/2 11.1 98100 Anchor-Vacuum Base (13" x 17") 35 15.9 98095 Anchor-Vacuum Drill Stand 75 34.0 98105 Vacuum Motor (115V) 60 Hz 16 7.3 16392 Vacuum Motor (230V) 50 Hz export 16 7.3 98110 Vacuum Motor With Fittings (115V) 60 Hz 18 8.2 16397 Vacuum Motor With Fittings (230V) 50 Hz 18 8.2 98115 Control Panel (115FV) 3 1.4 16387 Control Panel (230V) 3 1.4 98120 2 Inch Spacer Block (Applications over 10") 6 2.7 98125 20-Amp (115V) 25-60 Hz, 450/1200 RPM Motor 37 16.8 16382 10-Amp (230V) 25-60 Hz, 450/1200 RPM Motor 37 16.8 98130 Spindle Wrench 3 1.4 31360 No. 5 Strapwrench (for Bit Removal) 2 0.9 98140 Water Collector and Pump (115V) 19 8.6 16402 Water Collector and Pump (230V) 19 8.6 98145 Water Collector Ring 16 7.3 98150 Water Pump (115V) 50-60 Hz 3 1.4 98155 Pressure Tank: 8 gallon 11 1/4 5.1 Emerson Professional Tools Global RIDGID COUNTRY LANGUAGE Privacy Policy Terms of Use Sitemap ® 2009 RIDGID, All Rights Reserved WE BUILD REPUTATIONS
This unit is best for drilling in all types of cement and large aggregate`s, and marbles.
As for the Moh-scale in the range of 6.8 - 7.2
Best to hand feed the core and use a lot of back flushing the cut, to cool the bet.
Count on the cut`s time, to be about 10 minute to the inch.........
Jack in Oregon
Post by Jack, lapidaryrough on Sept 16, 2009 7:52:21 GMT -5
aunuts
Some days are gold, some are rocks. Either is cool.
Member since March 2006
Post by aunuts on Sept 18, 2009 0:42:33 GMT -5
I'd love some of the trimmings if there are any that aren't spoken for. Those spheres are going to be awesome. Jo
aunuts
Post by aunuts on Sept 18, 2009 0:44:59 GMT -5
& of course, I expect to pay for the S&H Jo
