BillyTee
Member since September 2009
Post by BillyTee on Sept 28, 2009 19:45:54 GMT -5
I am using the book, "Introduction to Lapidary" as a reference to help me learn rock tumbling. When setting up for the fine grind stage, (600 grit), it says to add a detergent. Then, when setting up for the polishing stage, it also mentions adding soap flakes. Can anyone tell me what is the best detergent to use, and the same for the soap flakes?
Post by johnjsgems on Sept 28, 2009 22:48:54 GMT -5
There have been many posts on this but not sure how easy they are to find. I don't add soap or detergent. After the 600 (or 500F) I "burnish" or wash the rocks and drum using a wet mixture of powdered Tide detergent. Borax is a more common burnish material. After polish I repeat the Tide wash cycle.
Steve
Member since June 2005
Post by Steve on Sept 28, 2009 23:00:03 GMT -5
My preferred soap for this is Ivory. I shave a bar of Ivory soap into flakes or powder - depending on how dry the bar was. I also occasionally use Borax. A couple of heaping tablespoons for a 12 lb barrel is plenty.
Post by 150FromFundy on Sept 29, 2009 6:10:44 GMT -5
Many use good old borax. Been around since people started washing clothes. Get it with the powdered laundry detergent. Look for "20 Mule Brand". Next to water, it's about the cheapest component of rock tumbling.
Many use it to "burnish" between the grit stage and the polish stage, and as a final wash after the polish. Add about 1 tablespoon for a 3 lb barrel and fill to 80% full with water. Run for several hours, or overnight.
Many will "burnish" between all stages of grit and polish. The idea being to completely remove all grit from the previous stage before moving on to the next stage. Personally, I think that is overkill for the 60/90 and 120/200, but makes sense for pre-polish and polish.
Every individual has their own recipe and technique. Don't be afraid to experiment and record your results. There are no hard and fast rules, just guidelines and recommendations.
Darryl.
Post by Toad on Sept 29, 2009 6:37:06 GMT -5
I use borax in every stage - seems to help wash off the slurry.
agatemaggot
Member since August 2006
Post by agatemaggot on Sept 29, 2009 10:22:04 GMT -5
Borax is a natural bacterial fighter also and will help to keep down pressure buildup to a certain degree.
BillyTee
Post by BillyTee on Sept 30, 2009 10:06:48 GMT -5
Thanks everyone. This definitely gives me lots to work with.
