jpb007
Member since August 2009
Post by jpb007 on Sept 30, 2009 10:43:57 GMT -5
I apoligize if this has been asked in another post. I never was clear when reading the different recipes for adding grit if it is measured by volume or by weight.
Thanks in advance.
Post by superioragates on Sept 30, 2009 10:47:52 GMT -5
I read somewhere that you should use 1 lb of grit, to 10 lbs of rock. BUT, someone on here, I think it was toad....... ? has a thread on just this subject. I think it's in the general rocks thread....but not sure. Let me look.......
Post by superioragates on Sept 30, 2009 10:50:09 GMT -5
Nope, it's in "lapidary tips", the very first thread in there, go check it out, if it doesn't help, then post another comment here on it, someone will definetly be able to help
Post by Hard Rock Cafe on Sept 30, 2009 12:27:04 GMT -5
Generally by weight, but I occasionally see posts referring to volume (e.g. 3 tablespoons), especially when referring to burnish.
Post by Toad on Sept 30, 2009 13:31:17 GMT -5
I do it by volume - a cup and a quarter for a 12 pound barrel.
Post by Hard Rock Cafe on Sept 30, 2009 16:14:04 GMT -5
I sort of do the same thing: I weighed the proper amount of each grit and put a fill line for each one on it's own measuring cup. Now I just fill to the line.
Grit weight doesn't change, nor does the volume. So a consistent volume = a consistent weight.
carloscinco
Member since July 2008
Post by carloscinco on Sept 30, 2009 16:58:50 GMT -5
I've always assumed that a recipe for tumbling, when listing the amount of grit to use in oz. or ounces, is referring to volume. It works for me.
Post by Deleted on Sept 30, 2009 17:13:39 GMT -5
Greeting Ladies & Gents, jpb007: Grit & polish is measured by weight, dependent upon your barrel average load set by the manufacturer. Both the general UK & USA recipes offered when you purchase either a rotary or vibe tumbler tends to be based upon volume rather than by weight, the rock they base their recipes upon is Chalcedony; Flint Agates (Moh's 6.5) for hardness; usually uniform hardness & needs to be reloaded or recharged every 7 days in a rotary tumbler. Both UK & USA recipes tend to be valid, but the USA recipe tends to be extremely too wasteful on expensive polishes. -- I hail from (The Barony of Seabegs) Bonnybridge, Stirlingshire, U.K, where aliens sometimes come for a visit & about 4 miles west from this monstrosity! Sticky's: Vendors worldwide, How to identify rocks & minerals!, FAQS: Add Tags:Save money on expensive grits & polishes!
Post by Jack ( Yorkshire) on Oct 1, 2009 2:28:52 GMT -5
Hi jpb007
I use the Tea spoon (weight method )
BUT I balance that with how the grit is used eg-- What is left over ,
Then tailor what I put in to the load so there is little or no grit wastage
Having wrote down these weights over the years , I have a good Idea how to charge the barrel to get the best and most economical use out of the grit used and the time it takes
(depending on Speed , Feet per Min travelled)
My Tumbler (self Built ) travells at 42 RPM
Keeping a log of your results is a great help and a must !! you will never regret it
Jack Yorkshire UK
jpb007
Post by jpb007 on Oct 1, 2009 7:46:38 GMT -5
Thanks for all the input.
Post by stefan on Oct 1, 2009 10:28:55 GMT -5
Personal Preference- I add it by the teaspoon, or in the case of my 12Lber by the cup. Measurments do not have to be exact- a little over or under really does not matter- the important thing is to not "rush" a stage- especially in the course grind.
rockdewd
Member since October 2007
Post by rockdewd on Oct 1, 2009 11:28:28 GMT -5
I use between one and a quarter and one and a half cups in my 12 lb barrels and 2 cups in my 15 lb. I run only 60/90 in my rotaries and finish in vibes. I've found 3 weeks is a good time span for all the grit to be used up in a 12 lb and 4 weeks in a 15 lb.
