zero
Member since October 2009
Post by zero on Oct 18, 2009 21:55:12 GMT -5
After telling my wife that I've always wanted a rock tumbler as a little kid, she actually got me a nice Thumler Tumbler as a gift a few months ago. I've already polished my first set of rocks that came with the set. It was all prepackaged, so I had no issues.
For my second set, I purchased a 4 Step Rock Tumbling Grit Kit and Magnesite. I didn't realize that the company would just ship one large rock, so breaking it up into smaller pieces was a challenge. For the first step, I just threw everything into the barrel -- dust, pebbles, and all.
I'm now on step 2. How small can the rocks be as I continue the process? I have a ton of smaller pebbles that came out of the process.. Are those safe to tumble or will they scratch the larger rocks?
I've also noticed that I don't have enough rock to fill 3/4 of the barrel. It only fills up to a little less than a half. The grit kit that I purchased came with a ton of plastic beads. Can I use these beads to fill the barrel to 3/4 or are the beads just for the polishing phase?
Second, can I reuse the beads, not on different steps, but on the same step for different rocks?
Next, will I have any issues if I tumble the rocks for longer periods of time -- say 2 weeks instead of 1 week? I have a trip coming up soon and I'll be gone for that period of time. I can have my wife check up on the tumbling to make sure its still going, but I'd like to examine the rocks as I take them to the next step.
Post by Toad on Oct 18, 2009 22:00:21 GMT -5
Try reading this: www.rocktumblinghobby.com/I'll try to answer the last question for you. I've never had any issues with a rotary going longer than a week. I always tried to re-charge every Saturday, but when the cycle has to go 14 days or even longer, I never had any problems. Wouldn't try it with a vibe though - they run with much less water, and in my experience need at least twice daily attention. But that's a problem for later. :-)
Post by parfive on Oct 18, 2009 23:46:50 GMT -5
Welcome to the board, Zero. You picked a challenge for your second tumble. Magnesite has a hardness of about 4, so it’s pretty soft compared to the rocks that came with your tumbler – usually around 7. You probably noticed how fast the Magnesite shaped up in step 1 compared to your tumbler rocks.
If those small pebbles you mention are also Magnesite, by all means throw them in there for filler. I wouldn’t bother with anything smaller than ¼”.
Use the plastic pellets in steps 2, 3 and 4. They help to cushion softer rocks from getting beat up, and also help fill the load. Reusable in the same grit. When you’re cleaning out the barrel, dump everything into a small bucket and float the pellets off into a strainer.
Step 4 (polish) would be ok for two weeks, but stick to one week for steps 2 and 3. Same reason again – you’ll just wear out the soft stuff. Good luck.
Rich
zero
Post by zero on Oct 19, 2009 9:52:07 GMT -5
Thanks for the link Toad. I read through that last night and it helped immensely. parfive, you could have fooled me, considering how hard it was to break up initially. I actually put a crack in my garage floor when I was pounding the magnesite with a hammer. However, you are right. The rocks shaped up really fast in step 1. Thanks for the feedback!
Post by Toad on Oct 19, 2009 9:57:14 GMT -5
I have an inch-thick metal plate that I bust rocks on - but I use it in the yard. Puts a small divot in the grass - but better than cracking the concrete. I'll probably set it on some 2x4's next time to disperse the pressure of the hammer blows a bit more. The plate is only 6x6 inches
Post by roswelljero on Oct 19, 2009 20:40:04 GMT -5
I have a steel railroad foundation plate (the thing the wooden 8 x 8s rest on) that I bust rocks on. I haven't dented anything since I got it. I've even used it on the kitchen countertop! I put cardboard under and around it to protect the surroundings and catch flying rock. Later, jeri
