sford13
Member since September 2009
Post by sford13 on Nov 2, 2009 12:10:49 GMT -5
Well I can hardly stand the excitement. Finally have my first batch in the polish stage. It has been a long road. Started out with a double 3# barrel Lortone from the Rock Shed. Now have two running. But that brings me to my question about the belts. I have ran the first tumbler for around two months now without stopping. No problem. Saturday was my day to check and re-charge and I noticed the barrels all of a sudden were barely turning. So I looked and the belt was very loose. So much so I had to tighten the motor mount almost all the way over. Is this normal? And what happens if it stretches more? How long should I expect a belt to last?
Edited to fix my spelling of Lortone. Was typing too fast.
Post by Toad on Nov 2, 2009 14:07:06 GMT -5
The motor is used to tighten the belt on the lortone - so I would say it is normal. But be sure your barrels aren't overloaded also.
sford13
Post by sford13 on Nov 2, 2009 14:59:33 GMT -5
I thought so too. But if they stretch much more there is not enough adjustment. Guess I will have to weigh my barrels and make sure I am not over loading them.
Post by Toad on Nov 2, 2009 15:04:42 GMT -5
I found that I easily go over the weight limit by loading to 3/4 full. Even 2/3 get's me their most of the time. For my QT-12, never had problems with the belt - other than having to adjust the motor once for tightening - and that was because I stripped the bolt.
sford13
Post by sford13 on Nov 2, 2009 15:23:27 GMT -5
Well over weight could very well be my problem since I make it a point to make sure they are usually always right around the 3/4 that they call for. I will have to dig out my digital fish scales and see what they weigh.
Post by johnjsgems on Nov 2, 2009 18:35:07 GMT -5
Lortones are notorious for stretching. Every "non-working" used Lortone I've purchased had a stretched belt. I never find a broken belt. If belt is fairly new it is possible that after initial stretching it will last a long time. I used up y remaining stock of Thumler's belts on the last bunch of Lortones. They are same diameter, slightly thinner and appear to be a tougher material. If you plan on running the Lortones full time you would be wise to have at least one spare belt and a set of shaft bushings. Lortone parts are very reasonable and available from the Rock Shed (or any Lortone dealer).
carloscinco
Member since July 2008
Post by carloscinco on Nov 2, 2009 20:21:32 GMT -5
It only takes a tiny bit of oil on the pully or belt to cause slipping. Clean with belt and pully thoroughly with a clean cloth if it's slipping. Don't use any cleaners.
