mcgrave
Member since December 2008
Post by mcgrave on Jan 3, 2010 11:55:47 GMT -5
Just wondering if when i am shaping a stone if i could use a belt sander. Can anyone help me on this subject. :help:
Post by catmandewe on Jan 3, 2010 12:02:00 GMT -5
I have a belt sander with silicone carbide belts and with diamond belts, it also has a water feed for belt cooling The Richardson's sanders are disk sanders instead of belt sanders, and they sand dry, but they have a little vacuum attachment that is supposed to cut down on the dust. With a little thought I am sure you could figure something out, just don't breath the dust.
Have a great day..............Tony
Post by johnjsgems on Jan 3, 2010 12:16:14 GMT -5
It would have to be pretty coarse sand paper to grind/shape. Dry sanding with 400 or 600 puts a pretty nice finish on rock. As mentioned the rock dust can be hazardous and the cheap dust masks are no use to keep the silica dust out of your lungs. Do a search on "silicosis" and decide if it is worth it to you.
Post by scared0o0rabbit on Jan 4, 2010 14:07:07 GMT -5
So does wet sanding eliminate the dust?
carloscinco
Member since July 2008
Post by carloscinco on Jan 4, 2010 20:11:56 GMT -5
Wet sanding reduces the airborne dust but even the atomized mist the belts throw off contains dust. Also if your belt sander is not made for wet service you could rust it up or electrocute yourself. The belts may also have to be made for wet service. I use 2x72" belt grinders (for another hobby) and the POP and slap when a belt breaks will get your attention. You'll have to pony up about $35 at a building supply store for a half face respirator if you want to avoid carrying a bottle of O2 around with you in later years. Well worth it.
