rockhound97058
Thundereggs - Oregons Official State Rock!
Member since January 2006
Post by rockhound97058 on Jan 29, 2010 0:54:19 GMT -5
Ok I have been on a mad rampage for the past couple days cleaning my shops and throwing out things I don't need or cannot use. Below are some goodies I had laying around which I have no use for. First is a Lortone CCU-6 Sanding Machine. Strange unit... Has a 6" sanding head tilted at a 45 degree angle. The machine is dirty, and the water tank is rusty! Needs some TLC to clean it up. The machine itself runs great. Also unsure if this came stock, or someone has added it to it, but it has a speed control mounted to slow or speed up the motor. It needs new sanding heads if you plan to run diamond, or stick with sandpaper. I do have the following to go with it. (1) - 5" 180 grit diamond lap (1) - 6" 180 grit diamond lap (1) - 5" 600 grit diamond lap (1) - 6" 600 grit diamond lap (uses the syringes) (1) - 6" 14,000 grit lap, (uses the syringes) and some sand paper. I'm asking $150.00 plus freight to get it out of my way!
Next I have a brand spankin new 9" Saw blade. It's a Sungem blade (made by MK). The size is 9" x .070" x .050 arbor. I'm asking $35.00 + shipping.
Next I have a brand new 6" x 1" x 1" Silicon Carbide Wheel. This is a 220 Grit stone. I'm asking $25.00 + shipping
Last I have a flat rate box of Richardson's Ranch Thundereggs. It's a medium flat rate with eggs from 1.5" upwards of 3"+. It weighs 24 pounds and I'm asking $35.00 + shipping.
imaginateer
Member since January 2010
Post by imaginateer on Jan 29, 2010 2:14:44 GMT -5
I want the last two items.
Post by morerockspleaz on Jan 29, 2010 5:03:51 GMT -5
I will take the thundereggs if imaginator does not take them. Man I should hae gotten up earlier lol.
BeLinda
Post by roswelljero on Jan 29, 2010 10:47:40 GMT -5
Sent you a PM about the Lortone CCU-6.
Later, jeri
Post by roswelljero on Jan 29, 2010 23:14:03 GMT -5
We'll I bought the "Strange unit..." Figured I'd try my hand at polishing some of my slabettes I can now cut with the WF. ;D Y'all be prepared for tons of questions. LOL
Later, jeri
imaginateer
Post by imaginateer on Feb 10, 2010 18:41:17 GMT -5
Got my stuff thank you so very much !
Mike
