bendsum
Member since October 2008
Post by bendsum on Jan 31, 2010 2:02:07 GMT -5
i found a highland park saw for sale the descriptions reads
"I HAVE A HIGHLAND PARK MFG. CO LAPIDARY SAW USED FOR CUTTING SLABS, CABS, OR GEODES. COMES WITH A 14" DIAMOND BLADE, AND SEVERAL OTHER BLADES, POLISHINGAND GRINDING WHEELS. PLUS SOME COMPOUNDS. MODEL M3 w/a ROCKWELL 1/3 HP MOTOR AND MOUNTED ON A WOODEN BENCH. ACTUALLY COULD USE A GOOD CLEANING. FROM A LARGE ESTATE AUCTION.
I REALLY DON'T KNOW MUCH ABOUT THIS ITEM. I WOULD LIKE TO KEEP IT, BUT I AM RUNNING OUT OF ROOM, AS I SEEM TO COVET EVERYTHING I BUY!
I WILL THROW IN A BOX OF ROCKS THAT CAME WITH IT. LOT'S OF AGATE, ETC. ""
sound like a good deal for $350?
Post by Woodyrock on Jan 31, 2010 2:51:37 GMT -5
You can not really beat the quality of Highland Park equipment. If all it needs is a good cleaning the $350 would be a good deal. The M-3 was sold as a 12"-14" saw, and had a lucite hood. The addition of more blades is a bonus if they still have life left in them. Offer less of course and see what you a haggle out. The vise opens to 5 1/2" with 4" of lateral movement. The arbor is a full one inch through the bearings and 5/8" for the saw blade. Woody
Post by roswelljero on Jan 31, 2010 3:52:06 GMT -5
bendsum are you near St. Louis, MO? I saw that exact ad on the St. Louis Craigslist. Later, jeri
bendsum
Post by bendsum on Jan 31, 2010 3:58:20 GMT -5
yep im down by lake of the ozarks
bendsum
Post by bendsum on Jan 31, 2010 21:40:23 GMT -5
Post by deb193redux on Jan 31, 2010 22:13:41 GMT -5
It may not be there next Friday. That price is about $100 low. The misc grinding wheels are just junk, but the slab grabber is worth about $35. The blade is worth at least $50 if it has half its life left.
I would jump on this.
Post by Rockoonz on Feb 1, 2010 1:24:23 GMT -5
I wouldn't wait either. Get over there ASAP.
Lee
bendsum
Post by bendsum on Feb 1, 2010 2:22:22 GMT -5
i talked to him and we aremeetin fri so i can check it out i wont have the $$ till thursday either way i dont wanna wait but have no choice
rockhound97058
Thundereggs - Oregons Official State Rock!
Member since January 2006
Post by rockhound97058 on Feb 1, 2010 2:58:48 GMT -5
Yeah $350 is a heck of a deal. Highland park was about the best machines made years ago. The only bad thing is parts are pretty limited for these saws - so if it breaks down some parts are readily available and others might have to be machined. Either way I'd go 4 it.
Just make sure the blade is fairly straight and not bent to heck. Also you'll need to check the alignment of the vise to the blade. Fairly simple fix. But just like a used car look it over good ;D
Good score!
bendsum
Post by bendsum on Feb 5, 2010 2:39:45 GMT -5
i am headed out in the morn its gonna be a 400 mile round trip and take all day i just hope the weasther holds till i am headed back home will post pics soon also depending on when i get this one cleaned up and runnin my home made one will possibly be up for sale
Post by rockmanken on Feb 5, 2010 7:53:17 GMT -5
I couldn't get Mark to come down on this saw. Was on craigslist last week.
bendsum
Post by bendsum on Feb 6, 2010 3:27:11 GMT -5
i brought it home everything works just gotta clean the dried snot out of the bottom its a lil thick barely clears the bottom of the blade the drive was fun snow there and home
NDK
Post by NDK on Feb 6, 2010 21:12:22 GMT -5
Nice find bendsum. Now get 'er cleaned up and start a slabbin'! LOL
Nate
bendsum
Post by bendsum on Feb 7, 2010 2:30:07 GMT -5
its all cleaned up and runnin cuts better then i thought it would it has a highland park conga blade and there was about an inch or so of hard gunk/rock snot in the bottom two things i may modify are the leather belt for the self feed and try to figure out an auto shut off
Post by sandsman1 on Feb 7, 2010 3:06:07 GMT -5
i don't know if you can make it work but the lortones use a piece of thin chain you can adjust so when the carriage gos so far it pulls the switch to the off position -- the lortone switch's have a hole drilled in them to hook the chain to -- mine went bad so i put a toggle switch in it and the chain hooks right to it and works fine
Post by sandsman1 on Feb 7, 2010 3:08:41 GMT -5
to clean the blade i bet if you cut a few slabs of obsidian it will clean it right up
bendsum
Post by bendsum on Feb 7, 2010 3:09:48 GMT -5
problem with this one is the motor is mounted in back and switch is on motor its not a must have more of a would like to have
Post by sandsman1 on Feb 8, 2010 0:08:58 GMT -5
hey maybe you could relocate the on - off switch up front-- im ok messin with 2 or 3 wires haha after that i get nervous
Post by Woodyrock on Feb 8, 2010 2:08:11 GMT -5
Highland Park saws came with a cutoff switch mounted on the front. They modified a push button switch by attaching a wire inside the switch. The wire went through a hole in the front of the saw box, and had a chain attached to the vise carriage. I would take a shot of mine, but I have been busy cuting, and the oil needs changing so it is a mess. Maybe some one has a clean saw they can post photographs of. The wire once broke off from my switch, and I can tell you that is a bugger of a job to put a wire in that switch. Diamond Pacific may have some of these switches. Give them a call. Woody
bendsum
Post by bendsum on Feb 8, 2010 2:48:14 GMT -5
hmm i dont remember seein a hole or anything mounted ont eh front other then the feed drive i do remember a chain hangin from the lid but it was to short to do anything i was thinkin rewired with a toggle on the front with a small cable hooked to the vice will wait for summer to do so have plenty of time to figure it out
