Shelbeeray
Member since January 2006
Post by Shelbeeray on Mar 5, 2010 1:41:49 GMT -5
Post by Hard Rock Cafe on Mar 28, 2010 7:21:56 GMT -5
Great tutorial Darryl!
As for drill speed, Yorkshire Jack recommends a much slower speed (rpm) to extend bit life. I haven't drilled any stones for a while, but it's worth a shot. You might ask him what speed he uses.
rockhunter
Member since May 2009
Post by rockhunter on Apr 14, 2010 12:26:19 GMT -5
Thanks! Great photos.
Jasper-hound
Member since June 2010
Post by Jasper-hound on Jul 2, 2010 10:38:44 GMT -5
I stopped using screw eyes and instead drill a larger hole totally through the bead. Like you, I tumble preformed beads I shape out of rock slabs. What I do now is drill through the profile of the bead and then silver solder a large ring of sterling through which the chain can then slide. This totally eliminates the possibility of coming apart, as a screw eye can still come out if subjected to enough heat to weaken the glue. c.a.
Post by Noosh9057 on Jul 21, 2010 9:16:27 GMT -5
Thanks for the great info.
Roger
chromenut
Member since December 2009
Post by chromenut on Aug 17, 2010 14:22:55 GMT -5
Well worth the price of admission! Excellent tutorial, one that I was looking for!!! Much improvement over the method I was using. Totally appreciate this!!
rocknrocks
Member since January 2011
Post by rocknrocks on Feb 1, 2011 9:44:49 GMT -5
Thank you for the great tutorial! will have to give this a try once my shop is fully set up
chromenut
Post by chromenut on Feb 1, 2011 17:50:29 GMT -5
I also agree with the comment about using a flex shaft. I switched to a flex shaft a few months ago and find it much easier to control my drilling that way.
zmd2008
Member since August 2008
Post by zmd2008 on Feb 10, 2011 13:03:06 GMT -5
Thank you for this great tutorial! I need to start some drilling one of these days and your tips and instructions are exactly what I need to help me get going.
Post by MyNewHobby on Mar 3, 2011 15:20:06 GMT -5
Just swung by to say hi and print these out as I may try some as soon as I get the final polish on a small batch.
Thanks again for posting this!!!
learn2turn
Member since February 2011
Post by learn2turn on Apr 14, 2011 13:04:24 GMT -5
Does anyone ever drill a hole straight through a pendant from front to back and then put a larger jump ring on it?
cryptocrystal
Member since July 2011
Post by cryptocrystal on Aug 12, 2011 13:47:57 GMT -5
Good technique thanks for the tips.
StoneCrazy
Stone Crazy
Post by StoneCrazy on Aug 12, 2011 18:45:09 GMT -5
Cool
apehanger
Member since April 2012
Post by apehanger on Jul 7, 2012 5:48:55 GMT -5
As a complete novice it is great to have these things explained so clearly.
Thanks.
borock
Member since April 2011
Post by borock on Jul 20, 2012 20:50:27 GMT -5
Very cool way of drilling.
Post by jamesp on Nov 2, 2012 7:27:59 GMT -5
The eye bolt is the way.My drilled holes are a bit sloppy.That system is anchor bolt city-it ain't coming out and it looks pro ffesional.Cold make my own 'eye-up' too with copper,brass, etc to match color of stone.Thanks
cherdarock
Member since December 2012
Post by cherdarock on Dec 27, 2012 4:14:44 GMT -5
Jump ring (silver) heart pendant (Blue Agate) silver chain. Made 7 of these hearts for Christmas presents! One other trick for drilling accurate holes is a dremel drill press. Center up and the handle will help with your drill "bounce" I personally start the hole under water, at a certain depth I then hand hold dipping the stone quite frequently. The hole has enough water for the drill. (mainly agates) Other stones need the tub as a lot of "mud" is generated. (the drill dust when dry is mud with water) When drilling I use the tinys, and the 1.5s and on really hard stone you can't be impatient unless you happen to have access to free drill bits. Some times you have to "dance" the bit to get a bite,(tilt the bit very slightly like "dipping" lol) and when drilling through a stone you HAVE to be straight, in the photo, if my exit hole was left or right just a smidge, it would show. the next size up burr will also "dress" a hole that looks kinda beat up. Excellent, excellent tutorial! Follow that lead for any drilling, and ALSO make sure your work area is just as neat! It will pay dividends. FINALLY! If you have bits that are too small/large for your dremel, it is your excuse to outfit that tool with ALL the collets (5) and a CHUCK, plus some of dremel's new quick change accessories. BUT! DEPOT is closed, so is the hobby store! WELL! Try heat shrink tubing! Tape and foil wrap have a high spot where the "end" of the wrap is. I have had drill wires cross the line and become whirling miniture weed whackers. Oh yes they do cut real good too! check for wobble prior to turning on the tool. ;D
pintoblades
Pinto Custom Blades
Member since May 2013
Post by pintoblades on May 4, 2013 15:23:38 GMT -5
Wow...being totally new in this hobby, this was truly an awesome tutorial....now at least I can make the wife a necklace! Thanks for sharing your info. Tools I actually have too! Bonus! I suppose it I were to pen some polished knife slabs to my knives, this method would work in some way.
Post by Pat on May 4, 2013 15:56:44 GMT -5
Good, right on tutorial. I've never drilled for a pendant, but I drill for rings. The clamps are a great idea.
It's important to lightly bounce the drill press core drill up and down to let water enter the hole and keep everything cool. Love those core drills!
Post by iant on Mar 17, 2014 2:34:21 GMT -5
Thanks for the excellent tutorial! I have the tools to start drilling but unfortunately I cannot find a supplier of these kind of findings in the UK. Are they known as the same thing in UK? Grateful for any tips.
Thanks again Ian
