Haleysdream
K-9 unit Rock Hounds
Member since January 2010
Post by Haleysdream on Feb 9, 2010 15:21:58 GMT -5
Hi Here are some new wraps. Also trying to get more that one photo showing. I should have 2 photos . Is it necessary to have 2 windows open to do this process??? One for the up load & one for the message. Any help is appreciated Ok just tried 2 more
NDK
Post by NDK on Feb 9, 2010 15:56:58 GMT -5
Great wraps Nancy. Your swirlies are much better than mine. Nice and smooth and even. Yuo chose beautiful stones to wrap too.
When I post, I open a 2nd window. Then I can type the message, and grab photos off photobucket as I type. It works well for me that way.
Nate
Post by NatureNut on Feb 9, 2010 17:09:51 GMT -5
Hey Nancy, doing good girl. Love Amazonite! I open up a second tab in Firefox, and then go between Photobucket and the message I am creating to make my post. You could use one window if you only had one picture, but with multiple pics, you will need more than one window or tab. I often have several tabs open and jump between sites that I'm on while on here. A perpetual multi-tasker, I am!
The second is my fav. Keep up the great work! Jo
damammy
Post by damammy on Feb 9, 2010 17:34:21 GMT -5
Great job wrapping the first three I like the best. Donna
Post by Bikerrandy on Feb 9, 2010 18:21:56 GMT -5
Those look great! I like the Marra Mamba best
Post by superioragates on Feb 9, 2010 19:44:10 GMT -5
Looks like you are progressing very nicely!! I like the 1st & 3rd the best!! Keep at it!! Marie
Post by montanamuskrat on Feb 9, 2010 23:29:56 GMT -5
Good design and workmanship . The blue is my fav. Deb and Tom
Roger
Post by Roger on Feb 10, 2010 10:17:40 GMT -5
nice work I like what you did on that wrap.
Roger
Post by frane on Feb 11, 2010 8:25:17 GMT -5
Looks like you are doing a great job wrapping! The only area I would be concerned with is the first wrap, the swirls that are out a bit on top to the left, may get caught on hair and clothes. Just tighten them up a bit at the loop ends and bring them in closer so the wire lays across the cab if you can and it will be perfect. Now, that is just my suggestion, not a rule so just take it for what it is worth. Keep up the great work! Fran
Post by NatureNut on Feb 11, 2010 8:34:19 GMT -5
I agree with Fran, another suggestion for the upper left ends on the first one is to bend them back and over the back. Think it might look cool. Doing great! Jo
Haleysdream
Post by Haleysdream on Feb 11, 2010 9:33:52 GMT -5
Thanks Fran & Jo & every one else. I appreciate the suggestions. The hardest part for me is the wrap around the bail, it it so hard to get tight & not slipping, plus neat & smooth.
Post by NatureNut on Feb 11, 2010 10:26:33 GMT -5
If you leave the ends of the bail on til you finish the wrap, you can use your pliers to pull the ends tight. Doesn't help tighten the center of that binding, but can tighten up the outer ends of it, then snip off the ends.
