mc2
Member since April 2009
Post by mc2 on Mar 18, 2010 22:35:05 GMT -5
This is the smallest cab I have tried making yet. 12x10mm. Making it for a ring. If you have not tried a small one yet, I can tell you that it is a real challenge! Just one small slip, grind a fuzz too much, and it's trashed! Very little room for error. Still, it was fun to make, and, looks like I got lucky. looks like it came out pretty good. Just noticed I need to wipe it down a little more, but, anyway, here it is: Thanks; Mike
Post by tkrueger3 on Mar 18, 2010 22:50:55 GMT -5
That's a very pretty little ..... um ..... tigereye? It'll make a beautiful ring, for sure!
Tom
adrian65
Member since February 2007
Post by adrian65 on Mar 19, 2010 0:09:07 GMT -5
Beautiful tiny cab! Did you do it freehand or w/ dop stick? Very nice chatoyance.
Adrian
Post by fishenman on Mar 19, 2010 0:17:12 GMT -5
Those little ones are tough to do esp. a soft stone like Tiger eye. Good job!
Post by NatureNut on Mar 19, 2010 0:43:13 GMT -5
Dude... that takes skill... and really short fingernails...
Post by Toad on Mar 19, 2010 7:39:38 GMT -5
Is it tigereye or chrysoberyl? Nice job regardless.
Post by rockrookie on Mar 19, 2010 10:20:58 GMT -5
thats is some precise grinding .great job !! --paul
Post by frane on Mar 19, 2010 12:13:19 GMT -5
You did a wonderful job on that one! Did you use tooth pics or a nail head to dop it on? I have been using nails for the small ones but I think I need to go to some heavy toothpicks for the really small ones.
Post by Tonyterner on Mar 19, 2010 13:39:30 GMT -5
Small ones like that sure are hard. You did a fine job. I like to use golf tees for the small ones. You can use either end depending on the size of the cab.
mc2
Post by mc2 on Mar 19, 2010 16:41:22 GMT -5
Ooops! Seems like I forgot a bit of info. I did indeed use a dopstick, a wood dowel, 1/8th inch diameter. And, it is tigers eye. Thank you all for your comments.
Mike
NDK
Post by NDK on Mar 19, 2010 19:28:52 GMT -5
Sweet cab Mike, that's gorgeous tiger eye!
One thing I found doing the few small cabs I've done is it's very easy to smooth/prepolish the cab out manually with a piece of wet/dry sand paper laid on something soft (I used craft foam). It's much harder to remove too much material that way.
Nate
mc2
Post by mc2 on Mar 19, 2010 22:09:53 GMT -5
Thanks Nate, that is a good idea.
Mike
fossilbrain
Cookie Monster agate
Member since October 2007
Post by fossilbrain on Mar 20, 2010 3:37:08 GMT -5
Lovely! Yes, I'm finally sorta dopping for the first time (actually doing the superglue trick) in order to pull off my first smallies. Inspiring -- thanks! Very nice.
nuevomundo
Member since March 2010
Post by nuevomundo on Mar 20, 2010 9:10:30 GMT -5
That is just precious! You look like you are almost ready for opals!
highplainsdrifter
Member since December 2008
Post by highplainsdrifter on Mar 20, 2010 21:41:09 GMT -5
very cool! I know what you mean about the small ones, they are really tough, especially calibrated sizes.
