Post by tortuga on Apr 11, 2010 20:20:10 GMT -5
When I first got my vibra-lap a few weeks ago, I had a lot of questions, one of which resulted in some good advice to draw some lines on the slab to see when it's even and ready for the next step. I have been using a sharpie for it, but I'm wondering if later one down the grit chain I need to stop doing this as the finer grits remove less material. Is there going to be a point when the fine grit wont remove enough of the material to remove the marker or should I be good to go through the polish? I'd rather ask now than scribble on something before the polish stage and find I have to return to an earlier grit to get it off.
Thanks, you guys have been an excellent learning resource for all my newbie lapidary questions!
NDK
Post by NDK on Apr 11, 2010 22:08:18 GMT -5
I don't personally have a vibe-lap, but I've read people use pencil to mark the slabs. I would imagine any ink based marking pen would pose the possibility of somewhat discoloring a slab if there's any porosity to it whatsoever.
Nate
Post by susand24224 on Apr 11, 2010 22:43:35 GMT -5
Hi, I don't "directly" know the answer to your question, but I do know that the so called permanent magic marker comes off easily with nail polish remover. On softer stones, I would test this first on the back--
Hope this helps!
Susan
Post by deb193redux on Apr 11, 2010 22:45:14 GMT -5
you only do this in the 1st grit.
you stay in 1st grit until flat. Other grits should remove scratches, but not change shape.
Post by sandsman1 on Apr 11, 2010 23:52:18 GMT -5
i agree with deb193 after first grit the slab will be even unless something goes wrong and mis shapes it -- id go with a carpenters pencil nice and thick easy to see and it wont be hard to get off if need be
Post by tortuga on Apr 12, 2010 10:34:20 GMT -5
makes sense! thanks again folks
riverbendlapidary
Member since September 2006
Post by riverbendlapidary on Apr 12, 2010 10:44:42 GMT -5
I use a thick piece of copper wire.
Post by FrogAndBearCreations on Apr 12, 2010 10:58:59 GMT -5
I use an aluminum nail/spike as it leaves a nice brite silver mark on the stone that is easy to see when cutting/cabbing. The nail I got at Home Depot and its for installing aluminum rain gutters
pebblepup
Succor Creek Thunder Egg
Member since July 2008
Post by pebblepup on Apr 12, 2010 13:44:13 GMT -5
You need to be careful with using a sharpie marker. I sometimes use them to mark problem areas on cabs. With hard agates this is fine but do it on a light colored jasper and you will run into problems. I did this on a white Willow Creek jasper with excellent orbs and had to sand for a long time to get through the stain it left. For a while I thought I ruined the cab.
Post by frane on Apr 12, 2010 18:07:20 GMT -5
I use an extra fine tip sharpie on most but some, I go with a scribe to leave a nice silver mark. I tend to use the sharpie on the pattern and the scribe if I am drawing a girdle line. If it is a soft stone, I try to stick with pencil (wears off too fast and hard to see) or the scribe. Fran
chromenut
Member since December 2009
Post by chromenut on Apr 12, 2010 20:22:10 GMT -5
I've been using those big, fat architect pencils, they've worked on every surface so far and are gone usually with the first coarse rubbing.
Post by stonesthatrock on Apr 13, 2010 10:14:16 GMT -5
ralph also uses a sharpie with no problems, so far.
mary ann
