smithnb42
Member since April 2010
Post by smithnb42 on Apr 12, 2010 16:45:05 GMT -5
Hi, I am really excited to be entering this hobby and was wondering if I should purchase the Lortone 3A tumbler kit? I have heard good things about Lortone. Also, is there anything else I should get with this? Any tips for my first tumbling?
Thanks
smithnb42
Post by smithnb42 on Apr 12, 2010 17:22:58 GMT -5
Thanks. I am very excited I think the bag of stones that comes with the kit should be ok but I will make sure I know which rocks to mix together for future batches.
Post by deb193redux on Apr 12, 2010 18:32:40 GMT -5
Hi smithnb42 -
To properly answer you question, instead of hastily proceeding to hardness issues, A little more information would be useful because the right machine depends on exactly what you want to do.
If you want to polish small (I stress the small) stones that you find, the 3a might be ok. The stones in the bag that comes with the unit are often slightly large, or disproportionately lacking the necessary small chips, that a good tumble batch needs.
Nothing much larger than 3/4 inch should be done, and 1/2 and 1/4 inch must be mixed in. With experience, you can sneak a 1" stone into the mix - but not several.
So if your size expectation is a little larger, then consider the Lortone 66, or the Thumlers Model B.
Also, do you plan naturally shaped nuggets, possibly with a little knocking/cracking to remove flaws and pointy bits, or do you plan to do flatter pieces that might make rustic jewelry? DO you eventually aspire to do some pre-shaping with a saw or grinder to make more professional looking jewelry? If so, a vibe tumbler might be a better choice.
Also, the kit generally never has enough rough grit. Most stones need repeated charging in the course grit, and they seldom mention this or give enough. So you might consider buying a unit form somewhere that can also provide a few pounds of grit at the same time.
Anyway, say a little more about what you expect and we can say more about what equipment/supplies to consider.
Post by johnjsgems on Apr 12, 2010 19:21:29 GMT -5
Kits always sound nice but I would spring for either a 33B (two 3 lb drums) or the QT66 Daniel mentioned. With two drums turning you can either do multiple steps or reserve one just for polish. Lortone is a good starter tumbler as is Thumler's Tumbler.
drjo
Honduran Opal & DIY Nut
Post by drjo on Apr 12, 2010 19:59:25 GMT -5
I agree with deb193redux and johnjsgems, their experience counts loads around here.
And the more we know about your endeavors the better the answers with be.
Glad you found us.
Dr Joe
drjo
Post by drjo on Apr 12, 2010 21:21:23 GMT -5
Can we stay on topic?
Post by johnjsgems on Apr 12, 2010 21:22:59 GMT -5
Not likely.
snuffy
Member since May 2009
Post by snuffy on Apr 12, 2010 21:37:50 GMT -5
I thought there were a couple more replies on this thread earlier from the "weezard". Oh,I had almost forgotten all the deleted posts he did the last time on here,the guy is true to form at least.
snuffy "thumbs down"
Post by deb193redux on Apr 12, 2010 22:09:23 GMT -5
Everything since 12-Jul is gone.
drjo
Post by drjo on Apr 12, 2010 22:23:08 GMT -5
smithnb42, Sorry for the derailed thread, pay no attention to the the person behind the curtain (he's gone now) Now back to business. Dr Joe .
snuffy
Post by snuffy on Apr 12, 2010 22:47:40 GMT -5
I would recommend the qt66 or the 45c.I've had a 45c for 20 years. I bought a 3a at a yard sale and it works for very small batches.I think if you get the 3a you will soon be wanting a larger one,wishing you had gotten one at the start.
snuffy
Post by Toad on Apr 12, 2010 22:54:02 GMT -5
The biggest one you can afford (and can fill). Lortone is A+ in my book.
gemhunter
"Rock On"
Member since November 2009
Post by gemhunter on Apr 13, 2010 8:43:02 GMT -5
Hello You got some great advise here already. I started out with the Tumblers, and I have added two extra barrels (I can only use 1 at a time), so that I don't mix grits and polish. I am looking to buy the Lorton double barrel from Johnsgems. Spread around the board is some great information. When I started I had some gems to tumble because I discovered the hobby while on a trip. But now I rock hound and buy some stones, and if your are like me you will fall in love with agates. They are great stones to start tumbling with. Ed
Post by johnjsgems on Apr 13, 2010 10:03:51 GMT -5
Ed, thanks but I'm not a Lortone dealer. Also not a Thumler's dealer anymore due to logistics issues but ,recommend both highly. I have an AR2 (2 3 lb drums) Thumler's. I can fill one or both drums. The single 3 lb is awfully limiting. Of course, if price is an issue or purchasing for kids it is a start.
