Haleysdream
K-9 unit Rock Hounds
Member since January 2010
Post by Haleysdream on Apr 13, 2010 19:21:38 GMT -5
Post by deb193redux on Apr 13, 2010 19:37:29 GMT -5
you need to go in each stage until the scratches are all similar in size. you can use a mag lens or try to get light to flash off dry slab and look for spots that are different. I would guess 4-5 min each grit after 1st grit, and then as long as it takes on final polish stage.
3000 is only pre-polish so you need 14000 or 50000 - best use some polish ordiamond paste on a leather disc.
some things like t-egg have parts the will not polish much, but agate center will
