Post by micmyers on Apr 26, 2010 14:25:25 GMT -5
Any advice to my rock tumbling problem is greaty appreciated.
I just started attempting to tumble rocks and it is just not working.
I have a Lortone Model QT66 and have tried tumbling several batches but get stuck at the same step every time.
The rocks for this first example I am using is Onyx, which I get from my granite countertop fabrication facility from leftover material. I used a 36 grit silicon carbide first (to try and shape faster, which i'm not sure really does). Then I used 90 grit silicon carbide to take the scratches off from the 36 grit and finish the shaping. Then I used 120/220 grit silicon carbide to take the scratches away from the 90 grit. At this point the rocks feel completely smooth and shaped, with no pits at all. They appear to be ready for prepolish stage. In the meantime I have thoroughly cleaned the rocks individually, and have also made sure that the barrel is about 2/3 of the way full of rocks, with the water level just below the top of the rocks.
When I move to the prepolish stage, I used 500 grit aluminum oxide, but everytime I do this the rocks come out pitted and white, and worse than when they left the 120/220 stage. It almost looks as though the rocks are dehydrated (that is the only way I can think to describe the look and feel). The rocks are anywhere from a dime size to silver dollar size that I have been trying to tumble.
After seeing this, I put them back into 120/220 to smooth them out again and it works, they are smooth and the pits are gone. I tryed skipping prepolish and went to straight to aluminum oxide polish(after cleaning) and even the polish is making the rocks pitted and white again. If I sample polish 1 rock by hand by rubbing it onto just polish by hand, it starts taking a polish with no pitting.
The rocks are not completely round. They are more of a rounded square or rectangular cube, and the edges appear to be more pitted and and white then the top of the rock.
The same as above happens when I try to tumble a granite called Emerald Pearl. Looks and feels good until I move to the prepolish stage. I have not added any other types of rocks to either of these batches, and even when I used a mixture of different types or rocks/onyx's in the same batch they are smooth and non pitted until I use the prepolish.
Why are my rocks being so difficult??
I have tryed using plastic pellets, and get the same result of pits. I have scrubbed the barrel clean with a toothbrush, I have scrubbed the rocks clean with a toothbrush. Is it the type or rocks? We polish granite by hand with diamond pads on a daily basis and the rocks do not pit, they shine.
I hope my descriptions are detailed and clear enough and again any advice is appreciated.
Thanks!
Thanks!
