Post by Deleted on May 8, 2010 17:06:55 GMT -5
Greetings Ladies & Gents, how do you load your rotary barrel? Note: media = burnishing agents (soaps), ceramic medium, grit, plastic medium, polish or & thickening agents. Empty rubber barrel weights: Evans (UK) 1.36kg (3lb) size = 0.60kg (1.32lb). Lortone (USA) 1.36kg (3lb) size = 0.50kg (1.12lb). Lortone (USA) 2.72kg (6lb) size = 1.45kg (3.19lb). Lortone (USA) 5.44kg (12lb) size = 2.40kg (5.29lb). 1: Everything; barrel, media, rocks & water = 1.36kg (3lb), 2.72kg (6lb), 5.44kg (12lb) or whatever. 2: Only media, rocks & water = 1.36kg (3lb), 2.72kg (6lb), 5.44kg (12lb) or whatever. 3: Dry rocks only = 1.36kg (3lb), 2.72kg (6lb), 5.44kg (12lb) or whatever. 4: Wet rocks only = 1.36kg (3lb), 2.72kg (6lb), 5.44kg (12lb) or whatever. 5: By volume, Barrel, media, rocks & water = 1.36kg (3lb), 2.72kg (6lb), 5.44kg (12lb) or whatever. 6: By volume, media, rocks & water = 1.36kg (3lb), 2.72kg (6lb), 5.44kg (12lb) or whatever. 7: By volume, dry rocks only = 1.36kg (3lb), 2.72kg (6lb), 5.44kg (12lb) or whatever. 8: By volume, wet rocks only = 1.36kg (3lb), 2.72kg (6lb), 5.44kg (12lb) or whatever. 9: By volume only (Not weighed)! -- I hail from (The Barony of Seabegs) Bonnybridge, Stirlingshire, U.K, where aliens sometimes come for a visit & about 4 miles west from this monstrosity! Sticky's: their contents are resource information 1: Vendors worldwide, 2: FAQS: Tags & Smilies, 3: How to identify rocks & minerals, 4: Save money on expensive grits & polishes!
Post by rockrookie on May 8, 2010 17:29:01 GMT -5
?? --paul
leadhand
Member since October 2009
Post by leadhand on May 9, 2010 14:53:15 GMT -5
Maybe I'm slow but I don't understand the question
Post by Deleted on May 11, 2010 3:24:20 GMT -5
Post by Jack ( Yorkshire) on May 12, 2010 3:02:23 GMT -5
revco
Post by revco on Jun 5, 2010 15:50:54 GMT -5
I too don't quite understand the question or too many answers apply to the way I do things. It depends on the stage and what I'm working with - so a blanket answer isn't really appropriate. I don't really care about weight, as much as I do volume because it's volume that produces a good tumble, not weight. I've found that 2/3 with rocks, water and media is usually close enough weight-wise, and typically a bit over, but my tumblers seem to be able to take it.
Post by Deleted on Jul 10, 2010 0:36:00 GMT -5
B U M P
