Post by bobby1 on May 13, 2010 21:43:43 GMT -5
.....Wiley Coyote is hiding behind the bush!!! This is a 3" wide cab of Paiute Agate. I slabbed this material about 20 years ago and had preformed it soon after. The preform ended up about 1/8" thick, which wasn't thick enough to stand alone as a cab this big so I set it aside for a (long) while. Yesterday I got off my a$$ and backed it with a slab of translucent Chalcedony so I could finish cabbing it. Finally, it is done!! Maybe some things get better with age (I have, hehe). Here is a side view of the back laminate. Bob
spokanetim
Member since October 2009
Post by spokanetim on May 13, 2010 22:00:28 GMT -5
Wow, I'm impressed! I really like that landscape and seamless backing. That one got better with age.
stoneviews
Member since April 2009
Post by stoneviews on May 13, 2010 22:06:23 GMT -5
Absolutely beautiful
Post by jakesrocks on May 13, 2010 22:31:00 GMT -5
Great job on the doublet. Beautiful cab, with a great picture. Don
Post by Woodyrock on May 13, 2010 22:39:31 GMT -5
Bobby: This is a real beauty. One day, I hope to see a show display of your work. Woody
Post by FrogAndBearCreations on May 13, 2010 23:27:33 GMT -5
that turned out really well!
a beauty of a cab
rons
Member since March 2010
Post by rons on May 14, 2010 9:16:43 GMT -5
great cab..better scene than a camera shot.. super work as usual ...love those larger cabs..
Ron
Post by stonesthatrock on May 14, 2010 11:25:19 GMT -5
very nice work. mary ann
gemhunter
"Rock On"
Member since November 2009
Post by gemhunter on May 14, 2010 11:26:42 GMT -5
Love it. Ed
Post by frane on May 14, 2010 17:47:08 GMT -5
Some just have to wait till the right time to do them. This was definitely the right time! I just love the scene in it! Fran
Post by fishenman on May 14, 2010 18:10:24 GMT -5
What a totally cool scene. You described it perfectly Bob.
aunuts
Some days are gold, some are rocks. Either is cool.
Member since March 2006
Post by aunuts on May 14, 2010 19:12:16 GMT -5
what a great idea! I never had thought of backing a cab with chalcedony, but it makes wonderful sense. it turned out absolutely gorgeous. jo
Post by Bejewelme on May 14, 2010 19:21:40 GMT -5
WOW that is a great piece and you held on to it for so long, WOW, I hope I can cab like you in 20 more years
Post by Bikerrandy on May 14, 2010 20:08:41 GMT -5
That's some beautiful work Bobby!!
NDK
Post by NDK on May 14, 2010 20:45:52 GMT -5
I'm amazed you were able to keep it from breaking, being it was so thin! It's a beautiful cab Bob, I bet you wish you did it sooner!
Nate
Post by NatureNut on May 14, 2010 21:57:11 GMT -5
Bobby, that is meep, meep, pachaaaang! ;D Jo
pporky
Member since May 2007
Post by pporky on May 15, 2010 4:02:59 GMT -5
Now thats what I call a cab, a real Bobby dazzler
SteveHolmes
Member since July 2009
Post by SteveHolmes on May 15, 2010 8:38:45 GMT -5
A real BEAUT no doubt! Thanks for the inspiration. Steve
karock
Member since November 2007
Post by karock on May 15, 2010 23:51:31 GMT -5
That is cool!. What did you use for glue and how fine did you grind the surfaces before gluing? karock
Post by bobby1 on May 16, 2010 0:35:01 GMT -5
Karock, I used Epoxy 330 which is the only adhesive that I ever use. I lapped the surfaces on a piece of glass with 120 grit tumbling grit. I keep grinding with fresh grit until the saw marks are gone and the piece has an even frosty appearance over all of the surface of each piece. I then add some fresh grit and keep working the piece until all the grit has broken down so fine that it no longer grinds. I repeat this on the other piece. I'm too lazy to wash everything and move to a finer grit. I then wash the pieces with warm soapy water and dry them with paper towel, being careful not to touch the surfaces. I then place them under my bench lamp to heat for a few minutes. On a sheet of white paper I mix the glue, slide it under the lamp to warm it then I glue them together. This is the same procedure that I use on any assembled cab including triplets. Bob
