Post by Donnie's Rocky Treasures on May 19, 2010 11:45:23 GMT -5
Thought I'd try something a little different using coated copper wire. As you can see some of the coating came off 'cause I was too rough! It's a tumbled stone 2" & not flat on the back so I am having problem with it laying right. I stuck a seed under the edge of it to get it to lay right so I could take a picture. Trying to come up with a way to fix the back so it will lay right when it is worn. Donnie Attachments:
Post by FrogAndBearCreations on May 19, 2010 11:47:35 GMT -5
nice!
Post by rockrookie on May 19, 2010 19:36:00 GMT -5
i like the look ,Donnie !! looks great !! --paul
Post by drocknut on May 19, 2010 23:08:19 GMT -5
Did you make the bail on top or towards the back of the stone? You might not be able to get it to lay flat but if your bail is offset a bit it might help. For me those tumbled stones are a real bugger to wrap. Looks like you did a nice job on yours.
tigereyes
Member since April 2010
Post by tigereyes on May 20, 2010 2:33:27 GMT -5
Looks very nice!
Post by Roller on May 20, 2010 8:44:52 GMT -5
have not seen that yet ,,, nice job
NDK
Post by NDK on May 21, 2010 22:17:33 GMT -5
That's a nice piece Donnie. I would think if you have the bail to hang straight, it will lay straight for the most part. Only one way to find out.
Nate
