dmharrisn
Member since March 2010
Post by dmharrisn on May 21, 2010 12:07:17 GMT -5
Can I reuse the pellets with a different gritt after the first gritt? I used new grit for the second stage, but do I need new from that stage to the 400? and the polish?
Post by Bob & Jordan (CharlindaBob) on May 21, 2010 12:48:50 GMT -5
I am new here also, and very green on rock tumbling, but I have read that you should change the plastic pellets every time you change grit, and especially for 400, pre-polish and polish stages. Don't throw the old pellets, just keep them seperated and marked for which grit you used them for and you can reuse them. I have learned that it probably isn't necessary to use them for the first tumble unless you have very soft material (rocks). Others in here will surely give you the straight scoop on this and are most helpful.
Post by johnjsgems on May 21, 2010 13:22:51 GMT -5
If you mean plastic what Bob said. If you are using ceramic media it can be washed with rocks and moved on each step. Plastic will embed with grit.
Post by rockrookie on May 21, 2010 19:02:24 GMT -5
i have been using the same pellets for months in the same size grit or polish . some times if i feel that they have been used long enough in onestage such as polish instead of thowing away i just back it off to 1000 grit or 1000 to 500grit and so on . always ging to coarser stage and never back to a finer stage . --paul
gemhunter
"Rock On"
Member since November 2009
Post by gemhunter on May 22, 2010 7:20:16 GMT -5
I don't think you want to mix grits (unless it's for breakfast) in your plastic pellets. I keep my pellets labeled in plastic bags just like my grit, so i don't put a heavy grit in with my polish or whatever. Ed
Post by FrogAndBearCreations on May 22, 2010 9:09:46 GMT -5
I do the same as Paul does, I will reuse a grit in a courser tumble but not in a finer than what it was first used in. I have mine labled in plastic bags to keep with the grit they were used in
