rcadamssr
Post by rcadamssr on May 25, 2010 11:15:11 GMT -5
I have a 10" saw-what is the max cutting height and depth that should be attempted? Thanks in advance for your input
Post by jakesrocks on May 25, 2010 11:40:22 GMT -5
It depends somewhat on the diameter of the large washer holding your blade, but a 4" X 4" rock should be safe. Does your saw have a power or weight feed ? If so, watch that the rock doesn't jam against the washer holding the blade. Happy cutting. Don
Post by Sabre52 on May 25, 2010 13:24:51 GMT -5
Yeah, with my 10" saw the maximum depth is controlled by space in front of the blade which is about 4 1/2 inches. Theoretically, I can go about 4" high on the workpiece but I usually try to keep it to three inches or so . The blade when old tends to bog down on those 4" thick cuts if the material is hard.....Mel
Post by johnjsgems on May 26, 2010 8:43:52 GMT -5
Most manufactured 10" saws will cut 3.5" tall but length is up to saw design and vise. If it fits in the vise it will be safe to cut.
Post by deb193redux on Jun 2, 2010 20:41:46 GMT -5
I find that thicker/stiffer blades fare better with 3+ inch cuts. thinner blade (.032 or less) any you should stay under 3"
Post by rocklicker on Jul 4, 2010 17:06:27 GMT -5
I tend to stay around 3 to 3.5 inches even with a thick blade. If your saw does not have an autofeed, make sure you go nice and slow to avoid heat buildup. I found the larger rocks tend to heat up in a 10 inch saw. Steve
