RedwoodRocks
Member since March 2003
Post by RedwoodRocks on May 26, 2010 15:02:03 GMT -5
Hi folks,
I am wondering how many pellets you use for the pre-polish and polish stage? I use about 1/8 pellets (or a little more) by volume for a Thumler model B, which is about 1" by height of the drum. And about 7" of rocks by height by the drum.
Thanks, Cal
Post by tkrueger3 on May 26, 2010 16:11:37 GMT -5
When I use either plastic pellets/beads or ceramic filler, I usually try to have a ratio of 1/3 plastic/ceramic and 2/3 rocks for the total load. If I'm tumbling softer materials, like sodalite or labradorite, I go heavier with the pellets and lighter with the rocks. Often, in a 50-50 ratio.
Of course, that's just me - others may have different methods.
Tom
Post by Sabre52 on May 26, 2010 19:17:10 GMT -5
Howdy Cal. I usually go with one full cup of plastic pellets in my 12 pound Lortone barrels and about the same amount in my UV-10 but the pellets do climb out of the load a lot in the vibe....Mel
RedwoodRocks
Post by RedwoodRocks on May 26, 2010 23:31:43 GMT -5
Ok, I messed, I should not have rushed through my question - I was hungry for lunch.
In any case, I wanted to ask the question as I wanted to move the tumbles to pre-polish after lunch.
I use one of those plastic Folgers cans to store my "ready for 120/220" rocks. The Folger can seems to hold the right amount of rock for a Thumler B tumbler. The Folger can hold 13 cups of rocks (I measured today).
After burnishing and cleaning the rocks, I put the rocks back into the barrel. The rocks filled 4 inches of the barrel. I added water to the bottom of the top level of rocks, added 2 inches of pellets and 7 heaping tablespoons of Tripoli. This left 2 inches of space at the top of barrel.
This is the formula that Tom uses (2/3 rocks & 1/3 pellets), which must mean that great minds think alike!!!
What I was sort of hoping for.....was that I was putting in too many of the rocks ready for 120/220 stage and I should cut back, which means I can run more lots through in a given year (I normally finish about 4 loads per year-running two Thumler B's).
I usually add stuff by sight (with very bad eyes LOL) - rocks, pellets, grit, water etc. If anything, I may not use enough pellets in the 120/220 stage, not that I notice too many fractured stones. I do try to have a good mix of sizes in all my loads. So, the small/tiny pieces help carry the grit and also cushion the bigger stones.
Ok, I am rambling... Cal
