cwernberg
Member since May 2010
Post by cwernberg on Jun 18, 2010 13:12:39 GMT -5
Hi, Our rock club has an old Highland Park E4 saw. There seems to be 1/8 to 1/4 inch play in the arbor. I assume the bearing is shot. The arbor housing is part of the saw table. Are these bearings replaceable? Any help appreciated. Chuck
Post by jakesrocks on Jun 18, 2010 13:58:43 GMT -5
Check your arbor to see if there are snap rings holding the bearing in place. If so, you'll need to use snap ring pliers to remove the rings. A few taps on the arbor shaft with a leather or other soft faced hammer should knock the bearing out. Check with Diamond Pacific. They may be able to supply the new bearing. They bought most of Highland Parks patterns and spare parts. Don
