Post by Jack ( Yorkshire) on Jul 16, 2010 3:11:20 GMT -5
Hi All Two finished off rings Ruths Carnelian Sorry this is a bit out of focus Moonstone single band 3.2mm "D" SS wire, 1, photoed on the end of a torch 2, bottom view 3 Top View I enjoyed doing this ring it only took a week spare time Coments and advice much appreciated, Jack Yorkshire uk
Post by Tonyterner on Jul 16, 2010 5:10:07 GMT -5
Very nice. I haven't tried a ring yet, I still have to get a mandrel. How did you make the twisted rope around the carnelian? I'm still in the infant stage of silver work so I'm always impressed with others work.
Post by moondragon on Jul 16, 2010 7:48:49 GMT -5
Great job:) Simple but elegant:)
Post by FrogAndBearCreations on Jul 16, 2010 9:20:13 GMT -5
Love the carnelian! Both look great!
Post by Toad on Jul 16, 2010 12:30:38 GMT -5
Nice work.
Post by frane on Jul 16, 2010 15:36:33 GMT -5
You are turning out some fantastic work! I think they both look great! Fran
NDK
Post by NDK on Jul 16, 2010 22:00:23 GMT -5
Both look fantastic! Nice work.
Nate
spicer m
Member since October 2008
Post by spicer m on Jul 16, 2010 23:36:20 GMT -5
Very nice rings, How about a pic of the pendant in the first pic MIke
Post by Jack ( Yorkshire) on Jul 17, 2010 3:00:19 GMT -5
Hi all Thanks for your comments , much appreciated Tony If your carefull you can use a big tapered punch and a raw hide hammer ! for ring manufacture 2 - I got a lenth of thin Silver wire and used a battery powered drill and a screw hook, Put the 2 ends in a vice , hook into the wire pull tight and turn till you get the required tention, Mike Just for you, front back This design above Im working on is made out of just one single lenth of wire , (1.5 Square) starts round the stone, over top Bail , one end to either side soldered on , insert stone then tightened by swirls both sides ? The above is the first attempt and has akward holding prongs on the back that I dont like The design dosent "Flow" right Another Pendant Im working on Thanks for looking Jack Yorkshire uk
janders
Member since February 2009
Post by janders on Jul 31, 2010 18:38:14 GMT -5
Jack, Very nice items! ;D Where can I get hold of the D-shape sterling silver, and is other sizes available?
spicer m
Post by spicer m on Jul 31, 2010 20:55:24 GMT -5
Jack Thanks for posting the pendents, Very nice. Mike
