dianeandkota
Member since July 2010
Post by dianeandkota on Aug 2, 2010 21:28:31 GMT -5
I bought this on ebay thinking it sounded like a good deal for polish on harder stones like agate and jasper. On my first try the rocks looked better after the pre-polish stage than after 6 days with the SC... ? Ran them again in AO polish for 5 day and looked great then. Ordered more AO polish a few days ago. 1500 Silicon Carbide? Anyone have any info on this??? Thanks!
Post by sandsman1 on Aug 2, 2010 21:49:02 GMT -5
hang on to it and use it for a pre polish when you run out of what your useing now -- prob not gonna work for a polish
revco
Post by revco on Aug 5, 2010 15:08:10 GMT -5
Yeah, most polishes are a finer grain than even 1500, so you probably wouldn't get any polish out of it. It would probably do you some good after a 500ish pre-polish. I do 1000 grit AO prior to polish and it helps me a lot with my success rate on mixed loads. I probably wouldn't try going from 120/220 to that...unless you left 'em in there for a couple weeks or so. It will also help with softer stones and those that have slightly porous surfaces. Hope that helps!
dianeandkota
Post by dianeandkota on Aug 5, 2010 18:10:15 GMT -5
Thanks revco....sounds like I'll prob. wind up with an assortment of types and grits, and thanks to everyone here, I should be able to put them to good use one way or another!
