Blade ?
Aug 14, 2010 14:30:04 GMT -5
Post by Donnie's Rocky Treasures on Aug 14, 2010 14:30:04 GMT -5
Well, it's time to replace my blade again - I used it all up! I have a Husky 7" tile saw & I have been using a 7" Hot Dog on it. Thinking about a MK 303 instead. Is there any reason why I can't use an 8" blade? It looks like there would be room for one? ? Donnie
redrummd
Member since July 2009
Blade ?
Aug 14, 2010 19:02:03 GMT -5
Post by redrummd on Aug 14, 2010 19:02:03 GMT -5
If the Husky is the Home Depot one an 8 inch blade will fit. I have an 8 inch on mine.....
Blade ?
Aug 14, 2010 19:48:06 GMT -5
Post by Donnie's Rocky Treasures on Aug 14, 2010 19:48:06 GMT -5
Yep, got it from Home Depot! Thanks!
Blade ?
Aug 14, 2010 20:07:06 GMT -5
Post by deb193redux on Aug 14, 2010 20:07:06 GMT -5
Select an 8" blade as thick or thicker than your Husky. Lapidary blades tend to be thinner, and when handfeeding rock, the thicker blade helps avoid bending the blade. This will be important as you add an extra 1/2" from the center hole.
Also, 303 will cut smoother, but not last longer. SO consider that it might be 2x the cost of the HotDog. Smooth is less important if you plan to grind a cab.
Blade ?
Aug 14, 2010 20:44:30 GMT -5
Post by Donnie's Rocky Treasures on Aug 14, 2010 20:44:30 GMT -5
Thanks - another thing to consider! Me thinks I need a trim saw, just a little 4" one for little trimming projects! Anybody got a used one? ??
Blade ?
Aug 17, 2010 0:25:48 GMT -5
Post by johnjsgems on Aug 17, 2010 0:25:48 GMT -5
Donnie, there is a 303C in 7" and it is thick too. As far as 4" trim saws I'll never use anything but an MK145 with a 4" 303C .020". At $130 list ($105 most Winter Sales) and available at a discount why buy used?
Blade ?
Aug 17, 2010 16:47:26 GMT -5
Post by Donnie's Rocky Treasures on Aug 17, 2010 16:47:26 GMT -5
Thank you, John! I will check both out!
Blade ?
Aug 17, 2010 21:02:19 GMT -5
Post by stonesthatrock on Aug 17, 2010 21:02:19 GMT -5
there you go donnie,,,,,, all kinds of things to condiser. I wish you luck. lol
mary ann
