celt40
KNIGHTHOOD FOR JOCK STEIN.
Member since July 2009
Post by celt40 on Aug 27, 2010 9:37:48 GMT -5
What size of motor would be needed to drive a 2 wheel 6" Arbor. Could I use an old bench grinder? Dermot.
Post by jakesrocks on Aug 27, 2010 9:54:52 GMT -5
A 1/3 HP motor should do it for a 2 wheel setup. If the bench grinder has a sealed motor, you should be all right. If the motor is open on the ends, don't use it. Remember, water and electricity don't mix. Don
Post by Hard Rock Cafe on Aug 27, 2010 12:51:28 GMT -5
You could still use the bench grinder motor if you set it up with belt drive. You _might_ be able to get away with 1/4 hp, but it might bog when you're grinding.
Post by johnjsgems on Aug 27, 2010 14:49:28 GMT -5
If you are shopping used either 1/4 or 1/3 hp. If new buy a 1/3. For some reason 1/3 costs less. 1725 rpm open drip proof or totally enclosed. Beware "open air over" motors.
Post by Hard Rock Cafe on Aug 27, 2010 15:05:05 GMT -5
I don't think you need capacitor start, but capacitor run would be a bonus if you can get it.
Post by Jack, lapidaryrough on Aug 27, 2010 15:39:12 GMT -5
contentious duty motor, ( Farm grade ) our better should be used.
1725 - 1750 RPM only, Check wheels for RPM speed range. as said above Hp. rating should be 1/3 - 1/2
Grinders RPM are about 3400, an there not rate`d Contentious duty.
Motors need three wire plugs ( GROUND wire must be used !!! )
Think Safety GFCI !
Jack in Oregon
