papat
Member since July 2010
Post by papat on Aug 28, 2010 18:27:26 GMT -5
i found an old western auto 6 inch arbor can i use this to buid me a grinder it has no bearings it has bushings would thi work if you keep it oiled or will the water hurt bushings and what size motor and how rpms
Thanks Tim
Post by jakesrocks on Aug 28, 2010 18:41:48 GMT -5
I wouldn't worry about water hurting the bushings. It's the grit fron grinding and sanding that will do the bushings in. If you can devise a way to protect the bushings from grit, that arbor will work just fine. Many an old timer built his own lapidary equipment, using this sort of arbor. I have one from Montgomery Wards that has sealed bearings. As for the motor, a 1/4 HP would probably work for a 2 wheel setup. 1/3 HP would be better. Most motors are 1725 RPM's Get a motor pulley the same size as the arbor pulley. Build yourself some pans and hoods, add wheels and a water supply and you're in business. Don
papat
Post by papat on Aug 28, 2010 19:27:48 GMT -5
thanks tim
Post by johnjsgems on Aug 28, 2010 22:25:55 GMT -5
What Don said.
