Post by tanyafrench on Sept 1, 2010 14:01:52 GMT -5
I just opened this, new to me, tumbler. There was no mud just water with the grit on the bottom looking like it has just been put in. I added water to the bottom of the top layer of rocks like in my 33B. Perhaps in this tumbler that is too much. Help, I want to reload and run it again as soon as possible. Tanya
drjo
Honduran Opal & DIY Nut
Post by drjo on Sept 1, 2010 19:54:34 GMT -5
How long had it tumbled? What are you tumbling? Is it facing N-S or E-W? Dr Joe .
Post by johnjsgems on Sept 1, 2010 20:12:56 GMT -5
More important is what size rocks are you tumbling? You need a real mixture including tiny or pea gravel or ceramic media to help carry grit and add contact. If you have all large rocks you won't form a slurry for a long time. Dr. Joe, everyone knows tumbler barrels have to have the lids facing East (coincides with Sun/Moon rising).
Post by jakesrocks on Sept 1, 2010 20:33:37 GMT -5
I thought that was only for Muslim tumbler barrels. And the tumbler has to sit on a prayer rug.
Post by Roller on Sept 1, 2010 20:35:30 GMT -5
wow... noone ever told me that ... the facing east thing ...maybe thats why I consider myself the worlds worst tumbler for the last year ...
snuffy
Member since May 2009
Post by snuffy on Sept 1, 2010 20:55:46 GMT -5
Trying to figure out how to get my lot-o barrel lid E-W snuffy
Post by johnjsgems on Sept 1, 2010 22:44:14 GMT -5
I drive through the Navajo Nation a lot. All the traditional hogan doors fade East. Not just a Moslem thing.
Post by tanyafrench on Sept 2, 2010 7:11:33 GMT -5
Now I know what I did wrong. I will try to re-orient the tumbler today with the lid facing east. Then I will wait a long time before opening it. Dr Joe, I am tumbling a variety of sizes of mostly agate, jasper, and Flint Ridge Flint and it ran for 1 week. My 33B barrels have to be recharged each week. It seems that is not the case with the 15 lb'er. Thanks for all the feedback, Tanya
NorthShore-Rocks
Member since December 2008
Post by NorthShore-Rocks on Sept 2, 2010 9:01:36 GMT -5
Something's up Tanya. A week should be plenty give or take a day or so. Most of the time when I've had a lot of grit left after a week, was because I was overloading the barrel with too much rock.
If you have the right amount of rock with a good mix of size balance, a week should work great.
One other thing to check. You mentioned this was a used tumbler. Count the revolutions of the barrel per minute and let us know what you come up with.
Steve
revco
Post by revco on Sept 2, 2010 9:33:14 GMT -5
My first guess would be the rock sizes. It's easy to be inclined to put a bunch of big rocks in these big tumblers, but you need plenty of small and medium sized ones too. Make sure your water levels are good too - just to the bottom of the rocks. (I sometimes use a little less in these big barrels because it creates a pretty thin slurry) Also, make sure you're not putting too much grit in - 1TB per pound and I'd suggest 12 in this tumbler.
I think a week is enough time to break down the grit, even in these big barrels. There's a definite learning curve with these larger tumblers, but personally, I've found they're less prone to issues than the smaller units. You can check the barrel every few days and if you don't see a good slurry or you see a lot of floating grit, chances are good you're experiencing the same issue.
On another note, I've been fighting similar issues since I've started using ceramics, primarily in my 3lb barrels. I know my size distribution isn't the issue and I've checked a dozen other things, but still haven't come up with a conclusive solution yet. For the time being, I've been vigorously shaking the barrel every day or two and this seems to help the load get by.
Post by tanyafrench on Sept 2, 2010 11:02:16 GMT -5
Okay Steve it is turning 16 revolutions a minute. I do have a variety of sizes and I did remove some stones yesterday thinking it may have been too full. Perhaps I do have too much grit as I put a cup in the first batch. Thanks for your help. I find I have so much to learn. Tanya
Post by tanyafrench on Sept 2, 2010 11:04:22 GMT -5
Wow Revco, I don't think I can vigorously shake this big thing. But I'll try. Tanya
snuffy
Post by snuffy on Sept 2, 2010 11:14:00 GMT -5
I just checked my lortone 12lber and it was 26 revolutions per minute. Dont know what yours is supposed to be.
snuffy
NorthShore-Rocks
Post by NorthShore-Rocks on Sept 2, 2010 12:01:42 GMT -5
Tanya, The reason I asked about the revolutions, was because I had the same problem when I fired up my used Model B. I decided to buy a new motor and rollers and refurbish the unit. That was a about 18 months or so ago and the unit has been turning 24/7 365 ever since. My "B" is now turning at 18 revolutions per minute. Now that may not seem like much of a difference, but over the course of a week, it adds up: That's 2 revolutions difference per minute 120 per hour 2880 per day 20,160 per week I'm not sure what the "B" is actually supposed to turn at (maybe JohnGems knows) but I do know that 1 cup of 60/90 grit should be exhausted in 7 or 8 days in a Model B producing an excellent thin slurry with agate and Jasper. You might have to add a little time because your unit is turning a little slower. I also think revco is right... you need a lot of little helper pea to dime sized rocks in your load. They're the workhorses of any tumble. 2/3 to 3/4 full (actually measure this and put a piece of masking tape on the inside of the barrel before you fill it, until you get a good feel for the load level. Take the masking tape out before you close the lid). Water to the bottom of the top rocks (as Revco said, you can back off this a bit) You should be good to go!
Post by susand24224 on Sept 2, 2010 12:11:32 GMT -5
Tanya,
I have nothing to offer as to the source of your problem. On occasion in the past the same has happened to me but I've never been able to pinpoint what the problem is. Sometimes I've reloaded the rocks, etc. and recharged and everything has been fine.
There are a lot of good suggestions here offered by people more knowledgeable than me. But if none of them work, I would suggest calling the Thumler people. 1-800-225-1017. They've always been really helpful to me when I called, and it wasn't always a call to order.
Good luck!
Susan
Post by Hard Rock Cafe on Sept 2, 2010 13:42:24 GMT -5
I use about 3/4 cup of grit and I fill only 2/3 full, with water level to the bottom of the top layer. You might try a little less water. I also recycle the slurry and gravel, and only use the tumbler for coarse grind. Even so, I find that my 15 lb. barrel doesn't round rocks as fast as my 50 lb. barrel.
Your RPMs sound close enough to me. I never use ceramics in a rotary---too expensive to grind into mud for me.
Hope that helps! Chuck
Post by johnjsgems on Sept 2, 2010 13:45:55 GMT -5
Tanya, first thing to remember is don't listen to silly people about facing west, etc. How you hold your mouth while opening the lid could make a difference though.
Post by tanyafrench on Sept 2, 2010 14:59:35 GMT -5
Okay, I have a lot to work with. I am going to open it now and add some of what was called Texas tumbling mix on Ebay which turned out to be pea sized rocks from a river bottom I am guessing. Ebay scares me after that. Anyway it will be perfect for some smaller filler and won't take up any more space. Just fill spaces. By the way John do I hold my mouth like I do when fishing? Please let me know. I already turned it to the East lol . Thanks for the phone number in case I can't figure this out any better. Blessings, Tanya
Post by jakesrocks on Sept 2, 2010 15:27:44 GMT -5
Hey Tanya, It's best to hold your mouth in a closed position, just in case the tumbler has built up gasses inside. That mud tastes awful, and getting the gritty feeling out of your mouth takes an awful lot of brushing and rinsing. Don
snuffy
Post by snuffy on Sept 2, 2010 15:33:49 GMT -5
Tanya, you mighta started that batch in the wrong phase of the moon,too.
snuffy
...just kidding yall
