slabber1
Member since June 2010
grit
Sept 3, 2010 12:22:56 GMT -5
Post by slabber1 on Sept 3, 2010 12:22:56 GMT -5
does your grit ever get old ?
grit
Sept 3, 2010 12:57:03 GMT -5
Post by jakesrocks on Sept 3, 2010 12:57:03 GMT -5
Depends on if you're using it. With use, it will break down into finer grit. If not, the stuff will outlive you in a closed container. Don
grit
Sept 3, 2010 13:07:35 GMT -5
Post by Hard Rock Cafe on Sept 3, 2010 13:07:35 GMT -5
Hmmm, not exactly sure what you mean. Silicon Carbide grit is pretty inert, so you don't need to worry about it over time. I suppose it might clump together if it got wet, but a little time in a tumbler with rocks would break it up.
grit
Sept 6, 2010 10:12:43 GMT -5
Post by Toad on Sept 6, 2010 10:12:43 GMT -5
Silicon carbide exists outside of space/time so it does not age. So in addition to Twinkies and cockroaches, after we're all gone silicon carbide will remain...
;D
slabber1
grit
Sept 6, 2010 17:45:03 GMT -5
Post by slabber1 on Sept 6, 2010 17:45:03 GMT -5
thanks toad that makes good sense to me
