slabcabber
Member since April 2010
Post by slabcabber on Sept 5, 2010 15:04:03 GMT -5
I was wondering if someone could tell me how much Cerium Oxide I need per pound of rocks in my tumbler. Thanks, Mark
Post by susand24224 on Sept 5, 2010 15:30:42 GMT -5
Hi,
I use about 1/2 TB per pound of rocks. I've read that you can use less, but have never tried it.
Susan
Post by johnjsgems on Sept 5, 2010 15:42:52 GMT -5
about two teaspoons in a 3 lb. drum.
slabcabber
Post by slabcabber on Sept 5, 2010 20:31:21 GMT -5
Thanks for the info Susan & John..
Post by Jack ( Yorkshire) on Sept 6, 2010 2:53:22 GMT -5
Hi Slabcabber,
Dont forget you can use the mixture over and over again I just used to add 1/2 a tea spoon of fresh CO now and again
Jack Yorkshire uk
slabcabber
Post by slabcabber on Sept 6, 2010 8:22:01 GMT -5
If I reuse the Cerium over do I need to run the polish stage longer ? Or do I just run it the same as I always do?
Post by Jack ( Yorkshire) on Sept 7, 2010 2:55:53 GMT -5
Hi I generally run just the same
Note on saving Polish, Colect all polish and washings from polished rocks stand in a tall glass jar to settle out Let it stand a week or 2 till the water is clear then pour off as much of the water as you can Leaving a thick paste of CO polish ready for the next batch
Hope this is a help to you
Jack Yorkshire UK
slabcabber
Post by slabcabber on Sept 7, 2010 8:19:36 GMT -5
Thanks A lot Jack for the money saving tips..Always good to save money ...
