papat
Member since July 2010
Post by papat on Sept 22, 2010 6:10:07 GMT -5
i put mineral oil in my saw is it Any better than water in a 10 inch
Thanks Tim
brent
Member since November 2008
Post by brent on Sept 22, 2010 6:50:50 GMT -5
I have tried everything. It's oil for me.
Post by deb193redux on Sept 22, 2010 7:41:48 GMT -5
Oil does make the blade last longer and keeps the saw from rusting. It is essential for heat control on larger saws. It is optional on 10"
Oil mist is an issue for me. I use oil in my enclosed 10" Lortone, but use water in my 10" BeaconStarr. I change the water every 2nd or 3rd session. I bleed off water and spray in water all the time. I use cheaper blades and use them faster. It fits me.
drjo
Honduran Opal & DIY Nut
Post by drjo on Sept 22, 2010 7:54:55 GMT -5
darrad
Member since September 2006
Post by darrad on Sept 22, 2010 14:08:04 GMT -5
I use water with a little "Dawn". I hand feed everything on my 10" and use the hot dog blade. They are sturdier than lapidary blades (.050) so they put up with a lot more abuse and are made to be used with water. I empty it after every use and spray it down with WD-40 to keep the rust and corrosion at bay.
Post by jakesrocks on Sept 22, 2010 14:27:14 GMT -5
I'd say that it depends on the material you're cutting. If it's a soft or porous material, use water. If it's a hard, non-porous material, use oil for the improved cooling qualities. I keep 2 blades for my 10". a thin blade for water, and a thick blade for oil. I try to do lots of softer material at one time, to lessen the number of times I have to clean my saw and change blades. Don
papat
Post by papat on Sept 22, 2010 15:42:09 GMT -5
thanks Tim
