conib
"... the secret is to bang the rocks together, guys."
Member since September 2005
Post by conib on Mar 6, 2006 14:44:22 GMT -5
Hello oh wondrous collection of rock-sages! I am wondering if anyone has anything at all to say about the Felker tile saws in general. And then in particular, I'm interested in the TM-75, and if I could talk you saw people into looking at these links (pretty-pretty-pretty-please!), I would be very grateful for any comments you'd care to share: Specs: www.felkersaws.com/new_TM75.shtmlVideo of it in operation: www.felkersaws.com/TM75.asfTryout/"Review": tileyourworld.com/tilesaw.htmWhat brought this saw to my attention was when I searched for "tile saw induction motor" after I read Ron's (MichiganRocks) post about how much quieter an induction motor is. Thanks in advance for your help! -- Con
rallyrocks
Member since November 2005
Post by rallyrocks on Mar 6, 2006 15:04:15 GMT -5
That's a pretty decent rig from the look of it.
Downsides from my view would be that it's only an 8" blade, the "radial arm" style means you'll need a rock vise of some kind, and at the list price of $366 you're almost playing in the league of real lapidary trim saws.
conib
Post by conib on Mar 6, 2006 15:24:54 GMT -5
Hey rallyrocks thank you for you post!
Your post brings up the question (and I hope this hasn't been done-to-death already, if so please forgive!)
What are your thoughts about the advantages/disadvantages of a real lapidary trim saw versus a tile saw?
-- Con
Post by stefan on Mar 6, 2006 15:33:47 GMT -5
Well the real lap saw is gonna have a much thinner blade- and is designed to cut rock- where a tile saw will have a thicker blade- and is designed to cut tile (generally flat material) but honestly for $88 the Workforce is hard to beat- It has a 7 inch blade- but has a depth of cut the same- Not that that is not a nice rig- it is- but when you start talking $400 your in another league.
KG1960
Member since August 2008
Post by KG1960 on Mar 6, 2006 15:45:37 GMT -5
Quite a few people here (Me, too!) have a Workforce 7" tile saw sold at Home Depot and seem to be very happy with what it is. It cost $88, so by spending $366 you gain only a half inch on the radius. I wouldn't do it. As has been said, you would also need some kind of clamp for the rock that is being cut. Also, visit Home Depot (and others) and see what they have. When I bought my 7" there, they also had a radial arm style tile saw much like the picture of the Felker but for a lot less money.
I think the main advantage of a true lapidary saw is that the blade is thinner, so you would lose slightly less rock per cut. Significant if you have small valuable rocks, but I never had a rock where the cut size would have been significant. You can always buy just a lapidary blade and install it on a tile saw, but most people seem happy with the blade that came with the tile saw.
Post by gemkoi on Mar 6, 2006 15:54:36 GMT -5
When deciding between a tile saw and lapidary saw, you must make up one very important point. Are you wanting it to split/slab rocks, or just for trim work?
See, all tile saws are made with scoring, or nipping slabs in mind. Which keeps the friction and abuse down on your arbor. Slab saws are very heavy duty arbors to handle the load of force generated when slabing a rock.
Now in any lapidary saw setup, you can buy super thin blades(prosilcer), or supper thick blades. YOu dont have this choice with tile saws. They are actually thicker blades in general because they are mint to "score" a tile. and will only ever fit a tile saw.
The abuse a tile saw can handle will be just as much as a trim saw from any lapidary manuf. But that only applies to trim, or scoring a slab. If you try to slab on a tile saw, you will not only were the arbor down fast, you will get blade warpage, and can possible kill the motor as well.
This model you are asking about has a direct drive 3/4 hp motor, you have a much higher chance of killing the motor if you plan to use it as a slab saw. Vers having a motor on a pulley behind the saw. AS this type of setup has give to any binding that may take place when trying to slab/split a rock. Even a trim saw shouldn’t be used to slab rocks, but you can do it, i use a 6inch trim saw to slab small pieces of gem rough, like Holley Blue agate, or Koroit Opals.
But tile saws are meant to only have the blade tip, cutting through the stone. AS soon as you raise this level of depth, by slabing a rough rock. IT can become very dangerous with direct drive motors. Does it have a speed control?
Just think about what may happen if your blade gets bound when slab/splitting a rock. ON a direct drive motor, it will over heat the motor, or break something on the drive. The worst case is the blade may break and send shrapnel at the user.
the workforce looks like a much better candidate in my opinion. I wonder if it direct drive too?
conib
Post by conib on Mar 6, 2006 16:03:23 GMT -5
Stefan, thank you for your post.
I'm definitely still weighing all the options, and looking for input.
The Workforce is for sure in there, especially because of the fact that so many people on the board have one, so there's a lot of information here to get me cutting rock! Not to mention that the price can't be beat. Also, it *is* more like a lapidary saw, like you say.
Is the reason that the depth of cut is the same on the 8" Felker as on the 7" Workforce due to the radial-arm configuration of the Felker?
(And BTW what do you call the way the saw is mounted on the Workforce and on typical lapidary saws?)
I've used crosscut sleds on wood table saws and as a result I kinda do like the idea of that sliding table. And MichiganRock's setup with the wood clamp and hold-down clamps seemed do-able. And I was looking at implementing a gravity-feed system.
But I have exactly zero experience cutting stone or tile, just wood, so I know my judgement w.r.t. features of various different saw configurations is not going to be the greatest.
-- Con
conib
Post by conib on Mar 6, 2006 16:20:48 GMT -5
Wow-wow-wow Shain fabulous input, exactly the sort of things I need to know. Yes, you're right in guessing that I was hoping to both slab and trim with the same saw. But now I see that I would be asking for trouble, and your post pointed out exactly what sort of trouble, if I want to slab with that saw. Good question about the speed control. I don't know enough about these things that's for sure because I don't know anything about when/why I'd want to be changing the speed. Duh, eh? I see on the trim saw I've been looking at (4" Ameritool) there's a speed control. Can you tell me a bit about speed control issues? -- Con
Post by rockds on Mar 6, 2006 16:46:17 GMT -5
for my money, I'd go with the work force but if your heart is set on this one it looks like a winner. Basicly you will pay 4-5 times more for this than the wf saw and pic up an additional 1/3 inch worth of cutting depth
Post by gemkoi on Mar 6, 2006 16:46:28 GMT -5
a speed control is a good thing to have on driect drive motors. As different hardness can and are effected by how fast the balde is turning at the tip. And the tip rotation speed will not be the same as the blade rotation speed, the more you get closer to the shaft(arbor) the more common this speed will be.
The main purpose of having a speed control would be as a fail safe in case the blade begins to slow down due to rock hardness. As you can always back off on the cut, as you cut the stone, if the blade begins to slow. However, with a speed control, you would be able to set it so the rock wont bind. IT would take longer to cut, but will do the job.
As the main problem with a blade getting bound, is to much force on the stone from the user, feeding it through the blade. Having a well located kill swtich is the minium you really need. INcase binding took place, kill the swtich. As well, with the worforce model, since the arbor and motor are under the work surface. If there was a problem with binding at all, it much easier to back off the blade, or stop the blade. When the motor is overhead, you are contored by minual rock space for feeding a rock through properly. So if binding took place, theres a much higher change of getting hurt. Thats gonna be you main concern really.
AS in my opinion, you can used just about anything to rock cutting, its a matter of how safe you want to make it be. So with a speed control on the Felker model, would be more safe than not having one. BUt on the workforce model, you wouldnt really need one for it. But as anyone really knowns, you can make a speed control for a few bucks. Just get a dimmer switch, that you can hook up to a plug. Plug you saw into the box, and the box into the wall, and you got speed control.
Post by Cher on Mar 6, 2006 17:32:03 GMT -5
Would you be able to roll a rock on that one to cut a larger size rock?
Post by gemkoi on Mar 6, 2006 17:35:05 GMT -5
YOu could, i suppose, but rolling a rock through to cut it, is a major casue of binding. I do it all the time on my 6inch saw, when the rough is say 4 inches on the cut plane. BUt again, with saws that have overhead mounted motors, these are fixed position. So if you get a rock stuck becasue of space, be very careful. As the motor wont have any or at least much give.
conib
Post by conib on Mar 6, 2006 17:36:54 GMT -5
Yep, I do think I'm being (oh so gently) talked into the Workforce. Way to go, cuz that means I can look into grinders a lot sooner than I thought I'd be able to. So yeah rockds, I hear ya, and fortunately, I don't have my heart set on anything except 1) getting something that will cut relatively thick slabs (up to 0.75") and maybe even slab small (1.5" or less) stones and do it in a relatively safe way. 2) it can't throw water very far, cuz I want to be able to use the saw in the garage during winter or when its raining, and among other sensitive things in the garage my husband has one of his home labs set up in there, so the water spray has to be able to be contained somewhat. 3) I do want to cut and shape gem-quality material (for fine jewelry) after I get some practice and so I would like to be able to use the very thin blades eventually. As for the dimmer switch, I had to giggle about that one. My poor husband hates dimmer switches, cuz they "put junk on the line". (He designs audio production equipment, and works on his projects here at home, so he's pretty sensitive about these sorts of things.) -- Con
Post by stefan on Mar 6, 2006 20:22:13 GMT -5
GemKoi the workforce is a direct driv motor- also a 3/4 HP- Conib- the closest thing I can think of to compare the Workforce too would be a small Table saw for woodworking- does that help at all as for slabbing- well the workforce does a good job on smaller rocks (say under 2 inches tall) and a passable job on anyhting under 4 inches- beyond that it is really tapped out- It is not a true slab saw and is not meant to be- But for trimming smaller stuff, trimming slabs, and turning knarled up tumbling rough into managable shapes- Well honestly it is the best 88 bucks I ever spent (actually I got mine on sale for $77)
Post by Cher on Mar 6, 2006 20:35:39 GMT -5
2) it can't throw water very far, cuz I want to be able to use the saw in the garage during winter or when its raining, and among other sensitive things in the garage my husband has one of his home labs set up in there, so the water spray has to be able to be contained somewhat. -- Con If you're doing this in the garage, is there any reason you can't rig up a place for a cheap shower curtain to hang around you so it doesn't allow any water to escape? I don't think you'd really need it but it would make you feel secure while using it.
KG1960
Post by KG1960 on Mar 6, 2006 22:05:13 GMT -5
Yes, a shower curtain arrangement may be the thing to do. There have been several posts on this forum with pictures of various splash guards people have made.
I do all my cutting outside in the backyard - no worries at all about where the water goes. For safety use it on a circuit with ground wire (the third prong on the plug) AND with a GFI. I don't see any reason to use a speed control with the Workforce. I have cut rocks up to 4" thick with two passes without a problem.
conib
Post by conib on Mar 7, 2006 20:07:16 GMT -5
Thanks Cher, that shower curtain idea is super, and I'm going to working on getting them set up around my "rock area". Thanks kg1960 for the heads-up about the GFI. I went to Fry's Electronics last night and picked up a portable GFI outlet. I also have some news: Okay, I know you all will be very disappointed in me, but it was a deal I couldn't resist ... I was able to buy and bring home a gently-used appears-to-be-very-good-condition Ameritool 4" Trim Saw with vise for $58.74 (inc. tax) yesterday evening. I'm going to post a new thread about it in a bit. Thanks again everyone for all your help. -- Con
