papat
Member since July 2010
Post by papat on Sept 26, 2010 6:13:00 GMT -5
i have a st 10 lortone what would be a good blade that want break the bank its got one that has the crimps around it dont like it leves marks on the slabs and do they all cut realy slow
thank tim
Post by Sabre52 on Sept 26, 2010 6:21:38 GMT -5
If you cool with oil like I do, the MK 303 continuous rim blade is hard to beat. Cuts so smooth the slabs almost look lapped. Usually runs about $80 or so but cuts fast and lasts a long while. The MK 301 continuous rim is even better and more long lasting but costs over $100. I'm running the much cheaper MK Criterion right now and though it cuts OK and lasts well, it leaves a much rougher slab surface......Mel
papat
Post by papat on Sept 26, 2010 6:24:56 GMT -5
thanks the power feed runs so slow takes for ever to cut a three inch rock takes 20 or 30 min
Post by johnjsgems on Sept 26, 2010 9:52:54 GMT -5
Slow is good. The slower the cut the longer your blade will last and generally the cuts will be smoother. Barranca (lapidary division of MK) has the same blades exactly as Mel mentioned. They will have them on Winter Sale starting end of November through April 1st normally. With the power feed you would want the .040" (153696 for 303C).
