juzwuz
Member since April 2010
Post by juzwuz on Nov 8, 2010 0:10:15 GMT -5
I finally bought a new 10" saw blade. Are there any tips on removing an old blade? How do people keep the blade from turning when you try to loosen the nut?
Post by Woodyrock on Nov 8, 2010 2:09:12 GMT -5
If you can not remember which way the nut unscrews, mark the direction on the saw for next time. Usually there will be a place you can hold the shaft with a small pipe wrench whilst turning the nut. Before installing the new blade, grease the threads so they will not bind up. Also, clean the shaft, nut, and especially the collars before installation. Woody
Post by rockmanken on Nov 8, 2010 7:04:49 GMT -5
The nut turns off the direction the blade turns. Looking from the front, if the nut is on the left, it turns clockwise for off. If on the right, it turns counterclockwise for off. Ken
Post by johnjsgems on Nov 8, 2010 7:52:07 GMT -5
What Ken and Woody said. Also when you tighten the new one it only has to be tight enough to not slip. Over tightening can dish the blade.
drjo
Honduran Opal & DIY Nut
Post by drjo on Nov 8, 2010 13:25:53 GMT -5
One word..."anti-seize" compound.
Dr Joe
Post by jakesrocks on Nov 8, 2010 13:54:28 GMT -5
All good sense tips. I keep the shaft from turning while removing the nut by gripping the belt and pulley in one hand, while loosening the nut with the other. The rubber belt gives you enough grip when squeezed against the pulley to prevent turning. Also, if any threads show beyond the nut, clean them real good before removing the nut.
Don
juzwuz
Post by juzwuz on Nov 8, 2010 15:48:03 GMT -5
Great tips! Thanks! I wanted to have a plan in mind before messing around on the inside of the oily saw.
Post by jakesrocks on Nov 8, 2010 16:08:54 GMT -5
While you have the saw opened up, and the blade off, you might as well clean it up real good. Save having to do it later.
Don
Post by tandl on Nov 23, 2010 10:28:38 GMT -5
Just hold the blade , how i do it . Mine comes off easy though . Unplug saw always before even getting near it .
juzwuz
Post by juzwuz on Nov 23, 2010 16:26:58 GMT -5
Just hold the blade , how i do it . Mine comes off easy though . Unplug saw always before even getting near it . Good tip on unplugging the saw....I always do that ever since one time I thought the saw's auto-feed had shutoff at the end of a cut when actually the rock had loosened and jammed the blade. I saw that the rock looked funny so I reached in and pulled back the vise which immediately started the blade again. I got a good mineral oil bath and a good lesson at the same time.
Post by tandl on Nov 23, 2010 17:15:05 GMT -5
My pulleys don`t have covers , on the outside of the saw , very dangerous . I`ve had two people want to see the rock while it was cutting ,pull the lid up and get soak with oil , head to groin .
MikeS
Post by MikeS on Nov 26, 2010 13:29:31 GMT -5
on my 12" saw, I'm able to grab the shaft (wearing rubber gloves for grip) and break the grip on the bolt with a sharp jerk of the wrench...mine is counter-threaded like most saws....
juzwuz
Post by juzwuz on Dec 12, 2010 3:39:23 GMT -5
I finally got around to changing the blade. I used tandl's method of holding the blade in one hand and turning the nut with a crescent wrench. It wasn't too bad.
I didn't realize the huge difference a new blade could make on the smoothness of the cuts. Actually I probably just didn't know how bad my old blade was. It's the blade that came with the used saw.
Are there any good uses for a worn out 10 inch blade or do I just clean off the oil and throw it in the recycling bin?
Post by NatureNut on Dec 12, 2010 7:43:55 GMT -5
I watched Randy change a saw blade on our last visit, and learned how he spins the blade slowly by hand after mounting it to check straightness. If there is a bend at all, he hand straightens it right there. He said that if it is seriously out of wack, he takes it back off and uses some straightening doo-dad that he has in his shop for working on cars.
