bgast1
Member since July 2010
Post by bgast1 on Nov 30, 2010 15:57:04 GMT -5
Does a vibratory tumbler accomplish the same feat as the barrel type tumblers?
snuffy
Member since May 2009
Post by snuffy on Nov 30, 2010 16:44:10 GMT -5
A vibe will speed up the process considerably. I always tumble the rocks in my barrels until they are shaped and ready for the vibe. 2 days in 1000 and 1 or 2 days in polish in the vibe,they are done.Just my method,everybody does it differently. I guess to answer the question, both will give you basically the same results in the end. You cant use the coarse in the vibe to rapidly shape rocks as it will wear the barrel .Really saves time in the end.
snuffy
Post by johnjsgems on Nov 30, 2010 20:28:32 GMT -5
Vibes are faster but will maintain shapes so you won't get the rounded pebbles like a rotary.
Post by Toad on Nov 30, 2010 20:44:11 GMT -5
Rotary for coarse stage. Either for subsequent stages
TByrd
Have you performed your random act of kindness?
Member since December 2010
Post by TByrd on Dec 1, 2010 1:53:00 GMT -5
Thank you so much, I have searched everywhere for info on Vibes, had a ten lb given to me but had no idea what to do with it.
drjo
Honduran Opal & DIY Nut
Post by drjo on Dec 1, 2010 7:55:30 GMT -5
Post by johnjsgems on Dec 1, 2010 10:43:11 GMT -5
10 b. what? Some vibes (like the GyRoc and Thumler's Industrial) handle rock or jewelry metals and some are light duty and only for dry polishing metals.
drdrew
Member since September 2010
Post by drdrew on Dec 1, 2010 10:52:45 GMT -5
i use the vibe for all stages. i like the more natural appearance of the stones retaining their interesting shapes. there are some drawbacks including some facets af stones that will not polish because they were not rounded. presently i am doing about 2 weeks in coarse (120 grit) before moving onto fine and polish. i do go through a lot of grit however needing to rinse and recharge about every 36 hrs.
