Post by Deleted on Dec 24, 2010 11:34:36 GMT -5
Hi Everyone, I am in the process of restoring an older RayTech cabing machine and it is missing two water valves. Would anyone know where I can find a similar valve without calling RayTech? I searched the internet for an hour and could not find anything. Thanks, Tim
drjo
Honduran Opal & DIY Nut
Post by drjo on Dec 24, 2010 11:44:48 GMT -5
That's an aquarium air valve, most are plastic now, but a good aquarium shop should have them.
Dr Joe
Post by mohs on Dec 24, 2010 12:43:45 GMT -5
Good clue Doc ! Tim, I'll keep my eyes open for a gizmo like that Ed
Post by jakesrocks on Dec 24, 2010 12:57:02 GMT -5
Covington carries all of the parts, including the spray nozzle that screws on the end of the valve. Your local hardware store should have the brass valves and all fittings except the spray nozzle, but you may have to change from plastic tubing to copper pipe. Don
chromenut
Member since December 2009
Post by chromenut on Dec 24, 2010 13:16:48 GMT -5
Post by johnjsgems on Dec 26, 2010 15:04:52 GMT -5
I use standard compression needle valves available at any hardware. The compression side comes with an insert for plastic tubing and ferrule for copper.
TByrd
Have you performed your random act of kindness?
Member since December 2010
Post by TByrd on Dec 29, 2010 21:38:16 GMT -5
I picked mine up at True Value. They are from $5-7.50. Good Luck Tbyrd
Post by rocklicker on Dec 30, 2010 14:41:38 GMT -5
I use compression needle valves like John say also. They work great and give you precise control over the water flow. Steve
