drdrew
Member since September 2010
Post by drdrew on Dec 26, 2010 17:45:18 GMT -5
Why cant i use 60/90 in a vibe? What if i need to remove a lot of material? Or will it destroy the bowl?
Post by johnjsgems on Dec 26, 2010 18:44:35 GMT -5
A vibe will maintain shapes so 60/90 mostly causes bowls to wear out. I've used it a time or two to remove matrix from fire agate rough, etc.
Steve
Member since June 2005
Post by Steve on Dec 26, 2010 19:09:38 GMT -5
Also 60/90 is too heavy for a vibe. It tends to just settle to the bottom and not stick to the rocks where it is needed.
drdrew
Post by drdrew on Dec 26, 2010 19:14:21 GMT -5
Interesting. Im going to try 12 hours of it tonight and report back.
Post by Sabre52 on Dec 26, 2010 20:44:21 GMT -5
I used to sometimes use 60/90 in my mini-sonic but mini-sonic bowls are really thick and not prone to wearing out. I'd think it would really chew up the thinner bowl types and as Steve has said 60/90 is pretty heavy and the moisture level has to be very precise to keep the heavier grit stuck on the stones without settling to the bowl bottom.....Mel
drdrew
Post by drdrew on Dec 26, 2010 21:18:58 GMT -5
That all makes sense but all i have ever heard before now is "its too aggressive" and well maybe tonight i was just feeling aggressive...lol! Actually though in my first few batches i am just wanting for more material removal, but oddly after about a week in 120-220, it seems like it sort of stops working, not braking down as much and not making as much slurry. I can see why people do the rough in a true tumbler but i guess im just trying to tweak my current formula...
Post by Toad on Dec 27, 2010 16:23:26 GMT -5
In general, rotaries are for material removal. Vibes are for sanding and polishing
Roan
Member since January 2008
Post by Roan on Dec 27, 2010 16:51:48 GMT -5
I tried 60/90 in my Lortone and in my Lot O', just to see how it would work. I didn't notice much of a difference except that the 60/90 broke down faster.
Post by johnjsgems on Dec 27, 2010 20:59:02 GMT -5
Generally in a vibe, grit is pretty much broken down in two days.
drdrew
Post by drdrew on Dec 28, 2010 10:24:27 GMT -5
so...the reason not to use 60-90 in a vibe is because it is TOO AGGRESSIVE LOLOLOLOLOLOL! 24 hours in raytech tv-5 tumble vibe does this. score for those of you keeping track = 60/90 grit -1 drdrew -0
Post by johnjsgems on Dec 28, 2010 10:39:30 GMT -5
That is where they wear through with too much water also. The grit settles to that level. Lucky for you, those bowls are pretty inexpensive.
Post by deb193redux on Dec 28, 2010 14:42:18 GMT -5
I had 60/90 do the same on Gy-Roc bowls. I have gotten a few extra batches out of thin bowls by putting a coating of epoxy, but the new bowl can be cheaper than lots of epoxy if it is a good one.
You might be able to get slightly better performance at a little more expense by buying straight 120 grit instead of 120/220.
As far as 120/220 losing its uumph after a few reloads, this si true. But it is the rock that is different. The initial sharp thin edges and bits of matrix come off quickly and make mud fast. Smoother rock, that still needs shaping, will not throw mud as fast, and you need to play with both grit and water to get something that forms the most effective and long lasting slurry. Sometimes it is more grit to make slurry faster, but on really hard rock, a little less grit actually seem to work faster. And what works in the Gy-Roc is not exactly what works best in the Vibra-sonic or Mini-sonic. I just feel my way along.
Happy vibbing!
drdrew
Post by drdrew on Dec 29, 2010 13:43:02 GMT -5
thanks for that input...makes sense as well.
