joejansal
Member since August 2009
Post by joejansal on Dec 30, 2010 10:13:40 GMT -5
hi all,
just read an old thread in vibe tumbling by bikerrandy, he gave great information, but don't see what size barrell he is using. i just got a vibe with a 5lb barrell, how much 120 grit do i use, also prepolish and polish. all help is appreciated. thank you joejan
Post by johnjsgems on Dec 30, 2010 11:30:09 GMT -5
GyRoc 2.5 lb. says 1 teaspoon. Try a little more than that and just enough water to dampen. You should see a coating on the load. What brand is your tumbler?
Post by 150FromFundy on Dec 30, 2010 16:26:35 GMT -5
I think bikerrandy is using a UV-10. ie - 10 lb bowl
I use 3 tbsp of grit or polish in my UV-10 and run 3 day cycles.
Darryl.
Thunder69
Thunder 2000-2015
Post by Thunder69 on Dec 30, 2010 18:56:58 GMT -5
It is a UV10 ...Cut the recipe in half and you won't go wrong...John
