blr2449
Can I retire now?
Member since January 2011
Post by blr2449 on Jan 7, 2011 13:30:34 GMT -5
I ordered and received a bag of Ceramic Pellets Large Cylinders from The Rock Shed. [great place, I WILL be back ]. Anyway, I began to wonder if I should have bought the small ones. When would one use the large vs the small cylinders? Thanks.
Post by Hard Rock Cafe on Jan 7, 2011 13:33:20 GMT -5
I use a mix of both in my vibe when I don't have enough small material.
blr2449
Can I retire now?
Post by blr2449 on Jan 7, 2011 14:02:25 GMT -5
Does that mean I should probably order some of the small and mix them when I need filler?
Post by susand24224 on Jan 7, 2011 14:55:56 GMT -5
I would mix them--the Little Red Store sells "premixed" by the pound; I *really* like the mix, but it is a bit more expensive than the Rockshed. There are some shapes in the mix that the Rockshed doesn't sell. I believe Johnjsgems referenced some triangular ones that he sells as well.
Susan
blr2449
Can I retire now?
Post by blr2449 on Jan 7, 2011 19:20:19 GMT -5
Thanks, Susan. I will definitely look into the smaller ones.
Post by johnjsgems on Jan 7, 2011 20:59:59 GMT -5
I would mix two parts small to one part large. The small will really speed up earlier stages as a grit carrier.
Roan
Member since January 2008
Post by Roan on Jan 12, 2011 0:49:31 GMT -5
I use a ceramic mix and throw in marbles, too. Marbles are fun
Post by johnjsgems on Jan 12, 2011 9:37:36 GMT -5
I lost my marbles a long time go.
snuffy
Member since May 2009
Post by snuffy on Jan 12, 2011 9:41:55 GMT -5
I used marbles in the past.Got some of the smallest Cat's eye marbles I've ever seen.lol
snuffy
Post by gr on Jan 12, 2011 9:43:14 GMT -5
HaHa John, I'm glad I'm not the only one! Thanks all for the good info on the ceramics.
Gary
blr2449
Can I retire now?
Post by blr2449 on Jan 12, 2011 19:33:51 GMT -5
Don't have marbles but I have a bunch of wonky beads I've made. I doubt they'd hold up. LOL The rocks are still Step 2 and I'm starting to put together another bunch. Before I do, I'll get some of the small ceramics. Thank you for all the help.
lloyd1wv
Member since December 2010
Post by lloyd1wv on Jan 12, 2011 20:12:43 GMT -5
I had a batch in a vibe that I allowed the polish to get to dry. I haven't found anything, including borax, that would remove it from tiny pits or cracks. I started the batch over again in 220 and run it until the dried polish was all gone. It had to run until those tiny pits were all removed.
