jody
Love our country because it Loves U.S.
Member since January 2011
Post by jody on Jan 11, 2011 2:11:17 GMT -5
:help: ok so I recently moved to the middle of nowhere and need some online grit shop advise or I have to drive 400 miles. Also I need soms advise on how to fix my vibe tumbler, I never even got to use. My son loosend the wing nut, he was checking on it, hes 4. and then turned it on. so now I have a big hole and a stripped main bolt. Help
Roan
Member since January 2008
Post by Roan on Jan 11, 2011 2:43:03 GMT -5
Jody,
Would probably help if you told us what kind of tumbler. What's the make and model?
Eileen
jody
Post by jody on Jan 11, 2011 4:30:04 GMT -5
Its just a chicago 5lb vibe tumbler
lloyd1wv
Member since December 2010
Post by lloyd1wv on Jan 11, 2011 8:53:34 GMT -5
It's hard trying to visualize the mechanics of what you have. But a few things come to mind. Can you use a second tap (nut) to allow you get to some good threads on the shaft? Can you use a washer to cover the hole that is too large? Maybe epoxy (if you have any) the washer into place? --I have also taken a stripped thread, coated it with epoxy, let it set 24 hours, and then "re-threaded" it by turning the tap down onto the damaged, epoxied, area.
I hope this helps a bit.
Lloyd
lloyd1wv
Post by lloyd1wv on Jan 11, 2011 8:55:58 GMT -5
Just one more thought: Is that center shaft mounted in such a way that it can maybe be loosened and then moved up or down from it's permanent mounting? That might give you a "new" threaded area where your mounting nut needs threads.
Post by Hard Rock Cafe on Jan 11, 2011 13:35:17 GMT -5
As for grit, many members buy from The Rock Shed. www.rockshed.comFair prices and service can't be beat. Chuck
jody
Post by jody on Jan 11, 2011 13:51:17 GMT -5
Thanks fo all the geat advise. I am gonna try the epoxy fix, and thanks for the website You guys all rock
Post by johnjsgems on Jan 11, 2011 15:06:07 GMT -5
If it was an American made tumbler you could unscrew the rod and replace with allthread (probably 1/4"-20). I'm guessing HF is Chinese and metric thread.
snuffy
Member since May 2009
Post by snuffy on Jan 11, 2011 18:49:23 GMT -5
I'm thinking the ce vibe is not made for rock tumbling,someone correct me if I'm wrong.Made for polishing shell casings,metal parts.
snuffy
Post by deb193redux on Jan 13, 2011 19:56:07 GMT -5
correct. I expect this tumbler will leak soon, or the bowl will wear through, or it will just stop. over time a few have tried and most report bad results. I think one person had some going for months with no problem, but I did not get any further reports
